Upgrade Loadcenter - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 09:46 AM   #1
Question
Upgrade Loadcenter
I added a sun room on to my 2005 modular home. I thought I had enough room in my panel for a 30 amp 240 breaker (for wall Heat Pump) and a 15 amp breaker for the rest of the rooms receptacles and light. The panel uses the mini breakers, you know the ones that control two circuits but are the size of one standard breaker. Well I won't have the space for the 15 amp circuit because I must use a AFCI breaker and I don't think they make the mini AFCI breaker like I described above. QUESTION: Can I install another small panel on top of the existing panel to cover my extra needs. And can I make splices in the panel because the wires are short. Thanks
fblankinship is offline   Reply With Quote
Old 10-27-2010, 10:16 AM   #2
Just call me Andrew
Rewards Points: 1,020
The rules for splicing inside the panel depend on your location...which is....?
Andrew
secutanudu is offline   Reply With Quote
Old 10-27-2010, 10:51 AM   #3
" Euro " electrician
frenchelectrican's Avatar
If the OP is in USA yeah it can be done but in Canada then no it is not allowed.
{ there are few USA local code may do not allowed splices in the load centre but I seriouslly doubt it }
Merci,
Marc
Old 10-27-2010, 11:40 AM   #4
My Location
I live in Weston Colorado.
Old 10-27-2010, 11:49 AM   #5
Old 10-27-2010, 12:15 PM   #6
Just call me Andrew
Unless local code prohibits it (doubtful) it is probably fine. Check the stickied threads for installing a subpanel - that's what you'd be doing.
Andrew
service upgrade needed ? 37victor3 Electrical 2 09-24-2010 10:51 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
400 Amp Upgrade / Transfer Switch AndrewF Electrical 50 07-04-2009 07:33 PM
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 10:15 AM
Upgrade Meter Box Help BenJoeM Electrical 10 10-24-2008 10:58 AM
