Upgrade On Electric Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 12:20 PM   #1
Upgrade on electric panel
What gauge of wire would be required at my main electric panel for me to have at least 100 amps or a bit more service?
Also another question, If a property has 200 amp 3 phase 4 wire service coming in from the street, what would actually be the max amount of amps for that service I would have available.
Baker John is offline   Reply With Quote
Old 07-21-2011, 02:10 PM   #2
Sparky
Rewards Points: 510
#3 THHN Copper, #2 XHHW Aluminum
200 amps.
Techy is offline   Reply With Quote
Old 07-21-2011, 08:55 PM   #3
Lic Elect/Inspector/CPO
2/0 cu or 4/0 al for 200 amp residential service
NJMarine is offline   Reply With Quote
Old 07-21-2011, 10:42 PM   #4
Rewards Points: 6,652
Only place that I could see having three phase, would be commercial or a large apartment building. Are you sure that you have 3 phase?
Old 07-22-2011, 08:35 AM   #5
I=E/R
a7ecorsair's Avatar
Baker John never finished his other thread....
a7ecorsair is offline   Reply With Quote
Old 07-22-2011, 08:58 AM   #6
The property I own is Mixed Use. Large home and a 1400 Sq. Foot Space formally used for many years as a full operation retail bakery. Althought the local Utility Supplier states the service coming in from the street is 200 amps. 120/208 3phase 4 wire. I am sure that the residential panel is only single phase. My problem is that I have a 70 amp. main breaker for the entire 4 bedroom home with electric clothes dryer as many as 4 window unit air conditioner running at any one time, and of course everything else with a typical home.
Old 07-22-2011, 09:07 AM   #7
I=E/R
a7ecorsair's Avatar
That is an excellent addition to the thread. At least we understand your service better. Is there more than one meter - the house and bakery have their own meter?
Old 07-22-2011, 09:32 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Are you tripping breakers or having other problems?
Old 07-22-2011, 09:45 AM   #9
I have never tripped the 70 amp main breaker as of yet. Occassionally a signal braaker if that area is overloading such as using a 12 vacume when window units are running etc..
But I am currently out of breaker in the panel and I need to move a couple standard 20 amp lines from one of the commercial panel located next to this panel and also I want to have 2 seperate deicated 20 amp line/outlets installed in 2 seperate rooms for use of air conditioners and other asst. items as needed. I feel I will be pushing the limit for sure and would need to upgrade at least to 100 amps. I know for a fact that the meter and the wire comming into the current panel are rated for no less than 100 amps.
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
wiring an electric sub panel located 130 ft from main panel jaramillo Electrical 4 06-04-2011 08:46 PM
main panel upgrade? cowboy dan Electrical 4 02-16-2011 08:02 PM
Breaker panel upgrade Jim Patton Electrical 2 11-04-2010 09:47 AM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 01:38 PM
