Upgrade To 200amp Or Add A Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 02:52 PM   #1
Smile
Upgrade to 200amp or Add a sub panel
Hey all,
I have a 100 amp service in my house and was wondering a few things. My meter on the outside is a Centron CL200 240V 3W Type C1SC TA 1.0 Kh. Does that mean I have a 200amp service going into the house? And if it is 200amp would it be cheaper to A. Upgrade to 200 B. Upgrade the box so I have more slots for breakers since my current box has no more room and keep the 100amp. or C. Add a subpanel. The wife and I are deciding on whether or not to finish the basement off and if we do so how much would we need to spend on the electrial. Any help would be appreciated.
Thank You
npaoline is offline   Reply With Quote
Old 12-19-2011, 03:07 PM   #2
Rewards Points: 1,192
The power company only uses that style of meter up to 200 amp. Bite the bullet and upgrade your service entry while you can.
bobelectric is offline   Reply With Quote
Old 12-19-2011, 03:58 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
The decision to upgrade to 200 amp service should be based on the load calculation not the number of slots in the panel. If the load is within the 100 amp capacity, you can replace the panel with one with more slots or use tandem breakers if your panel allows it. Adding a sub panel; for more slots can be an economic winner. First determine your load requirements.
Coastal South Carolina
Old 12-19-2011, 04:21 PM   #4
@ BobElectric,
With that meter being @ 200amp can I assume that it's already wired for a 200amp service or is it a 200amp meter with 100amp wiring going to the house. The house was built in 1989.
Old 12-19-2011, 04:27 PM   #5
I=E/R
a7ecorsair's Avatar
The only place that can give you the correct answer to your question is your power company.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
npaoline (12-19-2011)
Old 12-19-2011, 07:46 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Originally Posted by npaoline View Post
@ BobElectric,
No, it means the glass meter itself is good to use on UP TO a 200A service. The meter itself is actually meaningless.
If you have ANY other plans for the future, and your home does not use any gas (nat or LP) then an upgrade to 200 is probably in your best interest.
Old 12-20-2011, 03:06 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
^^That....
I upgraded my load center in 2000....went from 60A to 200A....I think I spent maybe $300 total.....I did all the work....hardest part was extending the existing ckts to the new location of the panel.
ddawg16 is online now   Reply With Quote
Old 12-20-2011, 03:35 AM   #8
You could also keep the old panel as a subpanel, fed from a 100a breaker on a new 200a panel. This reduces the amount of rewiring. The electrician doing our upgrade had the presence of mind to put a transfer switch between the old and new panels, such that a generator can power the old sub panel which contains most of the house circuits.
rubisco is offline   Reply With Quote
Old 12-20-2011, 05:10 AM   #9
IMO this has handyman or DIY written all over it. This is a classic tactic. VERY few professional electricians will do this. WHY keep the old breakers/fuses when you have a huge new 200A panel?
This was NOT "presence of mind". It was an upsell, and it is good salesmanship. It's easier and cheaper to do it during a service change.
It's not like he did it for free.
Main Panel Upgrade Invisible-Man Electrical 21 08-23-2011 03:24 AM
main panel upgrade? cowboy dan Electrical 4 02-16-2011 07:02 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 12:38 PM
