Old 12-11-2010, 06:48 AM   #1
Question
Upgrade to 200 or add subpanel?
I currently have a 150 AMP panel and I only have 3 circuits available on it. I am going to finish my basement which will have a family room, a bedroom, and a 3/4 bath. I feel like I need more circuits to do this properly. Should I upgrade to a 200 amp panel or just add a subpanel for the basement? The finished square footage in the basement will be about 800 SF.
Nschieffer is offline   Reply With Quote
Old 12-11-2010, 07:31 AM   #2
The limit on circuit breaker slots is 40, be it 150 or 200. If you have that many filled, consider a second panel. If you have a smaller panel(<40) replace the panel.
Old 12-11-2010, 08:05 AM   #3
Panel has plenty of capacity just add a Sub panel if your 150 amp panel is in good shape.
COLDIRON is offline   Reply With Quote
Old 12-11-2010, 03:12 PM   #4
I just upgraded from 150 to 200 I had a small panel and a sub panel. Now that I upgraded I have a large panel with 40 slots. I knew a guy so it cost me $1000 but it typically cost around $1800 to upgrade. So if you don't have any problems with current draw( lights dimming) then I'd say switch to a bigger panel or a sub panel
jairoc is offline   Reply With Quote
Old 12-11-2010, 04:26 PM   #5
nap
You talking to me?
nap's Avatar
actually, it was 42 but that limitation has been removed but I don't think you are going to see any panels with over 42 spaces anytime soon.
Unless you don't care for having a sub, adding one would be the most cost effective method. If you up-size your service, you are going to have to replace most everything from the utility connection to the panel.
as jairoc stated, unless your load actually calls for an up-size, there is not really any benefit to up-sizing.
Tags
basement, basement finishing, electrical, subpanel
Help please - Upgrading subpanel! wtfh4xx Electrical 24 02-01-2010 06:55 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
Subpanel Upgrade Rick Bruner Electrical 16 06-11-2007 12:19 PM
Add subpanel or upgrade main panel dcoz Electrical 1 01-12-2006 10:24 AM
