-   -   Upgrade to 200 or add subpanel? (http://www.diychatroom.com/f18/upgrade-200-add-subpanel-89299/)
Nschieffer 12-11-2010 05:48 AM
I currently have a 150 AMP panel and I only have 3 circuits available on it. I am going to finish my basement which will have a family room, a bedroom, and a 3/4 bath. I feel like I need more circuits to do this properly. Should I upgrade to a 200 amp panel or just add a subpanel for the basement? The finished square footage in the basement will be about 800 SF.
Just Bill 12-11-2010 06:31 AM
The limit on circuit breaker slots is 40, be it 150 or 200. If you have that many filled, consider a second panel. If you have a smaller panel(<40) replace the panel.
COLDIRON 12-11-2010 07:05 AM
Panel has plenty of capacity just add a Sub panel if your 150 amp panel is in good shape.
jairoc 12-11-2010 02:12 PM
I just upgraded from 150 to 200 I had a small panel and a sub panel. Now that I upgraded I have a large panel with 40 slots. I knew a guy so it cost me $1000 but it typically cost around $1800 to upgrade. So if you don't have any problems with current draw( lights dimming) then I'd say switch to a bigger panel or a sub panel
nap 12-11-2010 03:26 PM
actually, it was 42 but that limitation has been removed but I don't think you are going to see any panels with over 42 spaces anytime soon.
Unless you don't care for having a sub, adding one would be the most cost effective method. If you up-size your service, you are going to have to replace most everything from the utility connection to the panel.
as jairoc stated, unless your load actually calls for an up-size, there is not really any benefit to up-sizing.
