Originally Posted by gnharrold
I planning on purchasing a new tankless hot water heater and the specs on it say it needs a 200a service
It depending on where you located and water tempture { cold water side } and unit size .,
As far for my expernanice I allready done both North America verison and just not too long ago Europeain verison { I am in Paris France right now }
IMO the large one some are ok some are not worth a crap.
For point of use that will be ok but for whole house set up I really doubit it unless you get gas fired verison it may work better but both required larger service anyway { either electric or gas depending on which verison }
One house sometime back one person did have 2 whole house tankless heater BTW they are at 24 KW each naw .,, it is not a misprint at all and the service size it need min of 400 amp { 320 class metering set up } but end up putting in 600 A 3Ø 208Y120 system it seems work ok.
For European verison it is not much diffrent than what you see in North America system beside strict POCO regulations .,
Merci,Marc
