Old 09-18-2008, 09:59 PM   #1
unwanted voltage on coax
upon completing a satellite tv installation , as I went to cut the ground wire coming from the coax ground block, I had a large arc when my cutters also touched the weatherhead. I then got my voltage tester and the coax read 110 volts. I plugged the receiver into a couple other outlets and got a reading of about 50 volts. This is a real old house with only hot and neutral wiring and round screw in fuses. I know we need a electrican but what is the probable cause of this?
sat-man is offline   Reply With Quote
Old 09-18-2008, 11:34 PM   #2
Send a message via AIM to theatretch85
Ok, first of all, why were you going to cut the ground wire? The ground wire is there for a reason! Second, take a look at the following thread, someone else had a similar issue with finding power on the coax cable.....
Cable issue or wiring issue?
theatretch85 is offline   Reply With Quote
Old 09-19-2008, 05:47 AM   #3
I was cutting it from my spool to attach it to the service ground to complete the installation. I read the other thread , I think I will print it off and give it to the homeowner to give to their electrican. As of now they are using the satellite system with it plugged into a outlet that causes the coax to read 50 volts instead of the outlet right behind the tv which causes the coax to read 110 volts. And the coax ground wire is not hooked up. When it was plugged up behind the tv was when I ruined two satellite lnbs and I could have died.
Old 09-19-2008, 08:31 AM   #4
Ah, it sounds like a possible loose neutral...the return current has nowhere to go but ground.... this mostly happens on newer panels, with a ground block...
rgsgww is offline   Reply With Quote
Old 09-19-2008, 08:36 AM   #5
This was the end result in the thread mentioned above:
Originally Posted by Duchey View Post
Wow, took me a while to digg this one back up.
I cornered the LL a few days ago and finally got him to give me the whole story. Apparently the ground had been wired hot the whole time. He said that the wires had gotten "mixed up" at the main box back when the place was re-wired.
Darn lucky the place never burnt down.
There were quite a few things several electricians and cable guys tried, each one saying it was the other ones fault/problem.
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
