Unusual Receptacle Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 10:45 PM   #1
Hi. I have a house built in 1970.
I was going to replace the receptacles in one room which are all middle run when I found two things to be unusual.
First, the ground wires from each cable are connected to the two grounding screws on the metal receptacle box, one continues to the receptacle grounding screw and the other is cut short at the second receptacle box grounding screw. They are not pigtailed and are not connected to each other and seem to use the receptacle box for continuity.
The other thing I found unusual was the way the receptacle was wired. Normally the black and white of the first cable are connected to the top receptacle screws and the second cable, the black and white are connected to the bottom. The receptacles in this room are somewhat reversed. The black wire of the first cable is connected to the top screw and the white to the bottom. The black wire of the second cable is connected to the bottom screw is the white connected to the top.
My DIY receptacle checker tells me all is well.
My questions are:
- Should I bother trying to pigtail the ground wires and re wire them properly or is it alright as is?
- Should I bother rewiring the receptacle wires or leave as is?
Any comments or insights in this and why my receptacle checker tells me all is well would be much appreciated. Thanks.
Avanzi
Avanzi is offline   Reply With Quote
Old 01-19-2013, 10:50 PM   #2
Rewards Points: 13,458
Got a picture?
Are these a switched outlet? (one half of the outlet only gets power when a switch is on)
Old 01-19-2013, 10:50 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
Both are fine.
The Following User Says Thank You to jbfan For This Useful Post:
NJMarine (01-20-2013)
Old 01-19-2013, 11:53 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by jbfan View Post
Both are fine.
Agree X2
Old 01-20-2013, 04:41 AM   #5
Rewards Points: 77
Originally Posted by stubie
Agree X2
Agreed as well. Look to see if the tab on the hot side is removed. If it is intact, all is good
CheapCharlie is offline   Reply With Quote
Old 01-20-2013, 08:20 AM   #6
Thanks!
Thank you all. I can now move on with my life .
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 06:33 AM
Wiring 3 switches, 3 lights, receptacle RISurfer Electrical 3 08-07-2012 06:56 PM
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 01:18 PM
Wiring timer from receptacle intotao Electrical 7 01-21-2009 08:57 AM
Receptacle Wiring Question mpinchinat Electrical 11 12-23-2007 02:02 PM
