Unusual Electrical Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 07:29 PM   #1
Unusual electrical issue
Hello to all. I am glad that I found this forum, and hope to be able to assist some of you (with whatever knowledge I have) and certainly hope that you can help me with my problem.
I have an outlet which I use to plug my main TV into in the livingroom. I use a conditioned power strip to protect my equipment, plugging it into the outlet and then my TV, DVD Player, etc into the power strip.
Back in August I was watching the Olympics on my RCA 32" TV set. Suddenly it just turned off. When I went to turn it back on, nothing. No sound, no picture, zip. All you get is a red LED light (instead of green when it is on properly).
Originally and up until yesterday I thought it was a result of a blown transformer and/or shotty RCA craftsmanship as I did read up on RCA after the fact and read a lot of bad reviews about their products (who knew). However yesterday my roommate decided to take out the old power strip, put in a new one and plug in my older Panasonic TV so that we could watch movies/TV in the livingroom again. As soon as the TV was turned on, same problem. No picture, no sound, nothing.
The only common thing between the two (other than the obvious result) is the outlet. The only thing I could think of is that somehow their is a current issue there, but I'm confused because current should be consistent thru the entire house, right? The other oddity, as it were, is that it only affected the TVs that were plugged in; my DVD player and receiver work perfectly fine.
I am at a loss as to what the issue is. My roommate told me that she had an issue with the switch that controls the outlet some time ago (it was smoking or something?) and had an electrician come out who fixed it. The switch turns on/off the top outlet, but we were using the bottom outlet. There was also no problems with the outlet of this nature before or since getting it "fixed" prior to when the initial TV went dead during the Olympics.
Now it seems as though we have lost TWO televisions to the same outlet. We both have TVs in our rooms which work perfectly fine. As I said, this is a very odd problem, or at least it is to me.
If anyone has any ideas on what is wrong with the outlet, the TV(s) or anything else that might help resolve this please let me know. Thank you in advance for all your help and for reading this. I hope to hear back from you and to be a contributing member of the group.
LosLobo is offline   Reply With Quote
Old 11-09-2008, 07:33 PM   #2
I can't be to sure whats going on...I really think is a loose neutral on that outlet. Plug a lamp in that outlet, then plug something high load, like a space heater into it. Does the light go bright or dim? Don't leave the space heater on long though!
rgsgww is offline   Reply With Quote
Old 11-09-2008, 07:33 PM   #3
There are conditions that will send up to 240V to the 120V outlets.
You need to have a professional check the circuit out.
In my experience, TV's have built in protection and simply shut themselves off in these conditions.
Call someone.
220/221 is offline   Reply With Quote
Old 11-09-2008, 08:02 PM   #4
TV Protection
Thanks for the quick replies!
I wondered the same thing about the TVs ... don't most TVs have a fuse that would blow first if there was a spike or other issue?
I was wondering if there could be a 240V issue, obviously the surge protector would save it from a spike, but not the regular current. Any ideas on how much (best guess) it might cost to have it checked out/fixed?
Old 11-09-2008, 08:28 PM   #5
Checking it out shouldn't cost much, and fixing it really depends on what is not working (could be alot of things).
Old 11-09-2008, 09:49 PM   #6
So the TV's don't work anymore when plugged into other outlets?
Old 11-10-2008, 09:42 AM   #7
joed's Avatar
Rewards Points: 11,552
Are there any switches on the wall that you can't figure out what they control? Might control the receptacle.
If not a switch then a loose connection somewhere. Might not even be in the receptacle that is not working.
Old 11-10-2008, 02:44 PM   #8
A higher voltage for more than a second or so makes surge protectors smell bad and affects their performance in a negative way.
This would be somewhat in keeping the TVs having failed, if they have failed.
Now I'm thinking loose neutral. . .?
What's makes this tricky is that the surge protector, the TV fuse and the TV gizzards all have their own I-squared-T ratings, so it's hard to say what melts first, and what has just been wounded (so it fails later).
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
Electrical issue w/running Exhaust Fan/Light off GFI Exhaust Fan Electrical 1 03-20-2004 06:07 PM
