Unused Radiant Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 01:37 PM   #1
sparky89
unused radiant heat
I want to use 4 spaces in a subpanel (15 amp breakers) that are marked for the unused radient heat in the ceiling. They are all currently off and not used. I will be running 3-4 new circuits, for bathroom lighting, GFIC receptacles and smoke alarm circuits for this little remodel. (1) 15A, (3) 20A new circuits to be exact. I will cap off the old wires and leave in panel.
What do I need to be aware of when disableing this old 220 heat source?
Should I remove all of it at the panel or leave well enough alone and just free up the spaces I need? I was also going to remove the old wall controls blank them off. Any feedback on this? Thanks, guys
sparky89 is offline   Reply With Quote
Old 02-09-2011, 02:56 PM   #2
I think you've got the right idea of just removing the wires from the breaker and abandoning them in the panel, and then blanking off the old wall control.
Make sure to turn off your main breaker before removing and installing circuit breakers, and put some wire nuts on the ends of the abandoned wires to avoid accidental contact with anything else in the panel.
DetroitEE is offline   Reply With Quote
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Radiant heat and asbestos tiles sixsix General DIY Discussions 2 07-23-2010 09:00 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Radiant heat question tpagel HVAC 4 05-21-2008 04:57 PM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 08:58 AM
