Old 12-04-2008, 06:17 PM   #1
unused hot wire in wall
i have a hot wire that ran to a switch that i want to power with a new wire coming down from the attic. what should i do with old wire. its hot and it's on a ciruit shared with other outlets. can i just cut it, tape the end and leave it in the wall?
drewhart is offline   Reply With Quote
Old 12-04-2008, 06:20 PM   #2
Nope, you can terminate it in the box that you are using for the switch.
Or you can disconnect it at both ends and leave it dead in the wall tagged with "abandoned in place"
You might burn your house down the way you suggested...
rgsgww is offline   Reply With Quote
Old 12-04-2008, 08:05 PM   #3
should i terminate it by twisting a wire connector around it?
Old 12-04-2008, 08:37 PM   #4
To be code compliant you need to terminate it in an accessible, covered j box.
I'd tell you how to do it safely without a box but I don't want to start a whole thing.
220/221 is offline   Reply With Quote
Old 12-04-2008, 08:46 PM   #5
You said you were running new wire to the original box? just leave the old one in the box and put wire nuts on it.
Old 12-05-2008, 09:13 AM   #6
should i just use the old wire? they are knob and tube. the new wire is romex.
Old 12-05-2008, 11:10 AM   #7
Res Ipsa Loquitur
I would replace any knob & tube anywhere I could- the covering/insulation on that wire doesn't have the quality of romex bought today.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 12-05-2008, 12:11 PM   #8
Just cut the old wires at BOTH ends. You can leave DEAD lines in the wall.
installing wall box programmable timer rasta Electrical 8 11-12-2008 09:36 AM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
