Unused Conductor Termination In J-box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 01:52 PM   #1
Unused conductor termination in j-box
When a conductor of a cable (i.e. NM-B 14/3) is not used and is not connected to anything on either end of the cable segment (but wanting to keep it there in case it needs to be used in the future), what is the proper way to "terminate" it loose in the j-box? Snip any exposed copper and coil or tuck it away in the back? And/or does a small wire nut or tape wrap need to be put on the end? Should or can the unused conductor even be used like a wire tie to loop around its "sibling" conductors to keep things more organized?
sixspeed is offline   Reply With Quote
Old 08-24-2012, 02:06 PM   #2
joed's Avatar
Rewards Points: 12,892
Wire nut normally and just tuck in the box.
The Following User Says Thank You to joed For This Useful Post:
sixspeed (08-24-2012)
Old 08-24-2012, 04:18 PM   #3
put a wirenut over the unused wire and tuck in the box. Anywhere is fine. If you want to wrap it around it's brothers and sisters than that is fine also.
parman is offline   Reply With Quote
The Following User Says Thank You to parman For This Useful Post:
Old 08-24-2012, 07:19 PM   #4
So a wire nut is still required even though any exposed copper has been trimmed off?
Old 08-24-2012, 07:28 PM   #5
Licensed electrician
Rewards Points: 1,622
Just an additional safety measure should the conductor somehow get energized.
Old 08-24-2012, 08:48 PM   #6
When I open a junction box and see a random wire that is not terminated and has no wire nut, I start to think, "where does that damn wire go???" and I waste time figuring out that it's just a spare.
And as stated, safety in case it becomes energized for some reason.
leaving unused box knockout open amakarevic Electrical 13 11-05-2011 04:28 PM
Unused openned knockouts? WillK Electrical 15 06-02-2011 10:58 PM
unused radiant heat sparky89 Electrical 1 02-09-2011 02:56 PM
Unused large central closet to become Laundry room. Soupcatcher Plumbing 1 08-06-2010 04:01 AM
Closing Vents to unused rooms rguerra HVAC 0 07-04-2009 10:19 PM
