Unsupported MC Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2012, 09:20 PM   #1
Rewards Points: 135
See picture. I'm running to that switch location. I know I'm good running through the structural 2x4s, but I'm concerned about the last bit there, does the 6' support rule apply and I can just go across to the vertical member and support within 6' of my last bore hole? Also, within 12" of switch gang box, of course, that may actually do it?
smata67 is offline   Reply With Quote
Old 05-25-2012, 09:34 PM   #2
Rewards Points: 135
Oops. Maybe I need to unbore those holes, apparently 2x4 roof joists cannot be bored.
Old 05-26-2012, 07:33 AM   #3
Master Electrician
Rewards Points: 3,678
Never heard of a " 6' support rule". What is that structure, a storage shed?
brric is offline   Reply With Quote
Old 05-26-2012, 07:40 AM   #4
Licensed electrician
Rewards Points: 1,020
Wonder of the OP is thinking about a 6' flex whip to a fixture?
Old 05-26-2012, 09:51 AM   #5
Rewards Points: 135
It is in a shed and I'm using MC cable (it has a full size jacketed ground wire). According to this (p. 50), it needs support every 6' and within 12" of a box, unless I'm misinterpreting.
http://books.google.com/books?id=hot...ectors&f=false
Old 05-26-2012, 10:19 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm a little unsure of what you are confused about if you know the requirements of 12" from boxes, and 6' thereafter, but if you are asking if running the cable thru the bored holes is considered supported, the answer is yes.
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
