Unpolarised US Type 2 Plug To UK Plug. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 08:55 PM   #1
Unpolarised US Type 2 Plug to UK Plug.
Hi there
I live in the UK and have a compressor (of the music effects unit variety) which I bought set at 115v with a US Type A, Unpolarised plug attached. In one of the old maunals for the unit (there were several revisions), it advised UK users who wished to change to UK plugs that it was wired Blue:Neutral and Brown:Live etc. Also stating that the plug required a 3 Amp fuse. Straight forward enough I thought. Therefore, I switched the unit to 230v with the switch on the back and cut off the plug with the intention of putting a UK plug on it.
However, on cutting the US Type A, Unpolarised plug off the cable which is a two cable conjoined cable (kinda like headphone wire), I found out that this outer layer was the only thing covering the copper wire inside. Therefore, there are no colours there to wire correctly into a UK plug.
Would it matter which way around the two wires are wired into a UK plug? Doesn't the unpolarised apply to the UK too dependent on the unit being supplied the power?
What is the likely outcome should this wiring be wrong if the unit is switched on?
Kindest regards
R.
razorcut is offline   Reply With Quote
Old 05-15-2009, 09:32 PM   #2
Try these guys
http://www.electro-tech-online.com/s...earchid=799103
Lotta' electric/electronic-ally inclined UK/US people there.
Old 05-15-2009, 10:35 PM   #3
If it has an unpolarized plug on the unit it should be double insulated (unless a very old unit) and it shouldn't matter which wire is which. However it is always a good idea to check for continuity between the wires and any metal frame.
hayewe farm is offline   Reply With Quote
Old 05-16-2009, 12:33 AM   #4
Rewards Points: 2,350
Odd that it would be unpolarized, even if double insulated. But in the U.S. we usually identify which wire in neutral, even when the wires are the same color. Sometimes one wire will have small type letters. Or it may have ridges. This is the neutral.
Old 05-16-2009, 11:31 AM   #5
Hi there
Thank you very much for your replies everyone. I'll be sure to check that link Yoyizit.
Well...The unit works just fine wired into a UK plug.
Yes InPhase277 and hayewe farm. It's an old unit. From the 1980s I believe. This is probably why it lacks the additional layer of insulation.
When I got the unit, it was set to 115v. Therefore, being in the UK I used a step down transfomer with it. Once I realised it had a recessed and covered voltage switch on the back, I changed it to 230v and used a US to UK adapter. However, my confusion began when I had the bright idea of putting a UK plug on the thing yesterday evening.
Given what a couple of you have said regarding the polarity not beng an issue, and having had a look inside the US to UK adapter I've been using this past 8 weeks (see pics), it was apparent that this adapter didn't have anything fancy inside that would have made allowances for wrong wiring etc.
Therefore, using this adapter with the Type A, unpolarised US plug plugged into it either way around, would have presented each wire (in my unit's mains cable) to different UK plug pins. This surely means that my wiring of the UK plug (instead of continuing US to UK adapter) will have changed nothing safety-wise? Providing my plug is wired securely of course.
Incidentally, there were no ridges or markings on any of the cables. Do you thinnk it would be wise to take it somewhere to have a better cable (double insulated) put in and have it checked out? The person who had it before me had it for 20 years with it running smoothly without incidence.
Kindest Regards and Thanks
R.
Old 05-16-2009, 11:33 AM   #6
Thanks hayewe farm
This is beyond my capabilities and would likely have to be someone else. How would this be done though?
Regards
R.
Old 05-16-2009, 12:20 PM   #7
Originally Posted by razorcut View Post
Thanks hayewe farm
Regards
R.
You could do it with a cheap test meter found at the hardware store. But likely, if it had plug with no ground (you call it earth) pin, and it was made as recently as the 1980s, it is probably fine either way it is wired. AC doesn't care which wire is which, and the electronics within the device regulate the power once it is there.
Also, there may be a fuse inside the unit. If you feel like looking, the live wire will be the one connected to the fuse.
Old 05-16-2009, 01:05 PM   #8
Thanks InPhase277
I actually took a couple of pics when the unit (dbx compressor) was open. They are here. Note: that they were taken from the front of the unit looking toward the rear. Apologies for the first one being blurred.
There appear to be 3 wires which come from the a plastic part at the back of the unit, this I think is the voltage selecter switch on the back of the unit. These are not the cable wires which exit the unit (to a plug) but are before this stage. Looking at these wires from the front of the unit looking towards the back, they appear to be a Red (Left), Black (Centre) and an additional Black (Right). See first pic.
The Centre Black wire becomes one of my two conjoined mains wires which exit from the rear. The other two wires - the Red (Left) and Black (Right) go into the NTK gold coloured Transformer.
A White wire comes out of the NTK Transformer and goes into a white plastic cap where it appears to terminate (see pic 2). Out of this plastic cap, a Black wire comes out. This Black wire is the second of my pair of conjoined mains cable wires.
Does this look right to you?
There's a schematic here with the voltage selector etc at the bottom left of the page. I don't know if there's a fuse though. I have a 3 amp one in my plug.
Thanks and kindest regards
R.
Old 05-16-2009, 01:32 PM   #9
On double insulated devices the choice of which is grounded doesn't matter except with lights. You always want the ungrounded lead tied to the center button because you might come into contact with the outer edge of the base and you always want that to be tied to the grounded leg.
Old 05-16-2009, 02:35 PM   #10
Ok, the pics and the description helped alot. In the U.S. we use white as the neutral wire. The wire of the cord that is connected to the transformer's white wire needs to be connected to the neutral pin of your plug.
Old 05-16-2009, 03:09 PM   #11
It is totally unneccessary to worry about which wire is hooked to the grounded leg. With a nonpolerized plug it could be pluged in so the hot or the neutral was hooked to the white wire.
Old 05-16-2009, 04:53 PM   #12
For all we know, the OP meant unpolarized in that it didn't have a ground pin. Someone not familiar with U.S. plugs may not have noticed one blade wider than the other. In any case, while it may work either way, the manufacturer had a clear intent in mind when they wired the thing. The hot line goes to the voltage selector switch, and the neutral goes straight to the transformer. It would be best to stick to this convention.
Old 05-16-2009, 06:35 PM   #13
All windings of a transformer are isolated and insulated. The lead wire colors are pole designations and have little to do with conventions. The leads connect to no other device and there is no on/off switch. There would be no benefit in redoing the wiring.
Old 05-16-2009, 06:54 PM   #14
Why are you so against the guy doing it right?
Old 05-16-2009, 09:19 PM   #15
I just believe that in this case there is no right or wrong. Having bought hundreds of transformers even ones with the same part number with different colored wires for the poles. There is no standard for the transformers.
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 02:27 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
