Originally Posted by joed
You have a fan on the wall. That just wierd.
You only have one power wire going to the fan. If you switch it then you switch both the fan and the light. I don't know how an Insteon control works.
MDR !!! that is funny one .,,
Anyway to OP I don't know if you did see a single red conductor in the switch box if so that is the extra conductor that will go to the ceiling fan I have see that and I done that few time more than once.
Let make a quick break down I will go reverse of my normal pratice so you can able understand this very clear as long you have a single red conductor in the box that is your fan or light feed that will go up the ceiling fan you should able match this with black and white conductors aka 12 or 14-3 NM and that is the only one that go to the ceiling fan the other two { 12-2 or 14-2 } that leave that alone keep that exsting pigtail that you will need for the new combo switch and I know you have other black that go to the ceiling fan but pull the red one out hook that up then go up to the ceiling fan box you will see red conductor there and typically most fan useally have a solid black that useally used for fan motour while bleu wire typically used with light kit however some case you will see black with white stripe that used for light as well.
you should able see it pretty clear on that one once you get it done it will work very well.
Merci,Marc
