Unknown Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2016, 07:44 PM   #1
Solidify's Avatar
Rewards Points: 782
Unknown Bulb
These two bathroom vanity spotlight bulbs don't work anymore. How do I replace them? I don't know how to get the bulb out of the housing and worstly, I don't know where to find them/the model isn't clear. Can someone find it for me online?
Unknown Bulb-img_0656.jpg   Unknown Bulb-img_0657.jpg   Unknown Bulb-img_0660.jpg
Solidify is offline   Reply With Quote
Old 02-14-2016, 08:47 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 458
Try Googling the Model # and see what comes up. They look like low voltage (18v?) halogen so there will be a transformer somewhere in the cabinet header. As far as removing the lamp, I can't believe it would be sold as a complete unit but possible - then you'd have to be able to unplug it somehow from inside the cabinet. Partial turn lock? Threaded? Spring clips. I have low voltage halogen over my fireplace that are retained by spring clips but I can't remember how the bulb is connected. Maybe a Sparky will have better information.
lenaitch is offline   Reply With Quote
Old 02-14-2016, 09:21 PM   #3
Solidify's Avatar
Rewards Points: 782
I can't make out the model number... Lol anyone?
Old 02-14-2016, 09:44 PM   #4
Licensed electrician
Rewards Points: 1,028
It is a low voltage bulb. Looks like 30 or 50 watts at 12 volts.
Old 02-14-2016, 10:14 PM   #5
Solidify's Avatar
Rewards Points: 782
I think it says 30 but I wouldnt know where to look for it or how to remove it. I tried those suggestions but cant get the bulb out of the enclosure
Old 02-14-2016, 10:28 PM   #6
joed's Avatar
Rewards Points: 11,588
The front trim pops off some how. You might need to pry it bit with a screw driver.
Old 02-14-2016, 10:41 PM   #7
Rewards Points: 6,652
Look like standard recess mounted puck lights.
Old 02-15-2016, 07:16 AM   #8
Solidify's Avatar
Rewards Points: 782
Are you certain it comes out, before I start prying? Either straight out or unscrews...
Old 02-15-2016, 07:29 AM   #9
Master Electrician
Rewards Points: 3,680
The inside ring around the glass is friction fitted to the housing. Gently pry it out without using too much pressure which could break the lens.
brric is offline   Reply With Quote
Old 02-15-2016, 07:50 AM   #10
Short Circuit
Rewards Points: 52
It is 30W @ 12V. Ditto on brric advice to prying the light out
emtnut is offline   Reply With Quote
Old 02-15-2016, 09:47 AM   #11
joed's Avatar
It looks similar to the ones I used to have. It pivots to aims it. If you pry slightly at the pivot point they should come apart.
Old 02-15-2016, 10:42 AM   #12
Solidify's Avatar
Rewards Points: 782
Ok, I'll give it a shot and keep you posted.
Old 02-21-2016, 12:30 AM   #13
Solidify's Avatar
Rewards Points: 782
I replaced both burnt bulbs and everything works.
The Following User Says Thank You to Solidify For This Useful Post:
gregzoll (02-21-2016)
Old 02-21-2016, 05:06 AM   #14
Did you check the prices for LED units to see if they will give you the same light, but without the heat and yellow color.
Old 02-21-2016, 07:36 AM   #15
Solidify's Avatar
Rewards Points: 782
No cuz it wouldnt have fit in the vanity cutout. I just wanted a quick fix. These lights aren't used often anyways:
Replacing a light bulb 94dgrif Electrical 2 01-13-2013 01:38 PM
"Final" bulb in parallel circuit brighter than rest. Why? 7.62 Electrical 11 04-30-2012 05:13 PM
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Remove A Broken Light Bulb Floyd Chandler Electrical 0 08-14-2011 03:50 AM
