Unisaw Wiring Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 08:18 PM   #16
Rewards Points: 264
If you need oem parts try Joe at Plaza Machinery in Vermont.
I understand about you wanting to keep it original, but there are some things you can do to make it safer. A kick stop is one. It will complicate your sorting out the electrical issue, but if you ever use a table saw with a kick stop you will probably never want to go back.
7echo is offline   Reply With Quote
Old 01-02-2009, 08:40 PM   #17
BUILDER / REMODELING CONT
buletbob's Avatar
Originally Posted by dgr68 View Post
Bob- Where did you get the contact? Also, did you think of just switching to a new switch with overload- a la the Grizzly ones? I'm chasing this around because I'm curious and would like to keep the machine true to original but I'm getting near the end of the rope.
I took it to a place like Granger's and they matched it up for me.
Old 01-02-2009, 09:09 PM   #18
Idiot Emeritus
Rewards Points: 1,492
The motor on this saw is thermally protected, thus satisfying code requirements.
A simple toggle switch (light switch) that's rated 2 HP at 120 volts would be code compliant.
One of the biggest reasons that a controller like this was installed from the factory is because if the power fails during a cut, the saw will not re-start when power is restored. The start button would need to be pushed again. With the toggle switch, it will re-start if the switch is still on.
For what it's worth, my table saw has had a toggle switch on it for over 25 years.
Rob
micromind is offline   Reply With Quote
Old 01-03-2009, 09:16 AM   #19
Thanks again all. Rob- you think I'll be OK running it w/out thermal overload at the switch? I would love to get the thing running- tough I do want to figure out what is wrong with that controller still.
dgr68 is offline   Reply With Quote
Old 01-03-2009, 02:45 PM   #20
Rewards Points: 58
I noticed that the OP pushed the contactor in manually. I must take issue with this type of behavior.
Pushing in a motor contactor manually is very dangerous. If there were a short in the motor or wiring the contactor could blow up in your face. I know someone who was severely burned doing this. If you must manually push it in, please disconnect the motor and measure the voltage instead.
Old 01-04-2009, 06:08 PM   #21
The problem is the overload. I bypassed the control loop on it with a jumper and the contactor engaged and stayed engaged when I pushed the start. Question is- what do I do now? There doesn't seem to be any way to push the red stick so I don't think it is tripped. Is there a fuse in it?
Old 01-04-2009, 06:53 PM   #22
Rewards Points: 150
My guess would be a new overload.
Steelhead is offline   Reply With Quote
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 01:29 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
