#16 |
Licensed Pro
Unique problem - House main trips, but nothing else - only when dryer is on
You've got a loose connection in the main wires at that burned lug. You will need to remove the main wires, cut away the damaged portion and re-install. If there is not a disconnect at the meter, you will need an electrician to pull the meter and repair this. Do not use any high load appliances (dryer, range) until this is fixed.
#17 |
are my eyes deceiving me or is that a strand of the neutral wire hanging beside the hot lug?? if so it may be arcing with high current demand from the dryer.
#18 |
Electrician philosopher
Goodeye greg..WTF is THAT!!! Why won't it do it on the oven as well, though?
#19 |
thats what i was wondering, because the oven usually draws more power than the dryer. It appears all the breakers are turned on in the panel, which one is for the dryer?
#20 |
dont know the answer for that Andy.You would think on broil it pulls as many amps as the dryer.Maybe its the dryer and other combinations ie.heatpump??
#21 | |||
Unique problem - House main trips, but nothing else - only when dryer is onQuote:
It's a tinsle-like piece of plastic of some sort. I pulled it off. |
#22 |
Unique problem - House main trips, but nothing else - only when dryer is on |
#23 |
Solidground, my already cold ridden sinuses were going to make my whole head explode
if you didn't say the oven caused the problem also. Replace the breaker yourself...or have an electrician do it. Up to you. Post back on the results! The photos were excellent and I'm sure we would all love to see photos of the panel with the breaker removed, if it is not to much trouble.Andy Edit to add...there is still a small possibility that the panel will have to be replaced. Also...if there is no outside disconnect, then you will HAVE to have an electrician do it. Last edited by Andy in ATL; 11-24-2007 at 08:56 PM. |
#24 |
Thanks guys. Sorry to hit you so hard on my first day.
I'll try to take it easier on you in the future. My name in Bill, by the way. I'll look for an introduction thread or something. Just know that I appreciate your time and input. |
#25 |
"Son of a beach. It is doing it with the oven's broiler on.]"
Try and limit your electricity usage until you get some help. I dont know exactly what circuits you have on, or how long this problem has been going on or what has been added. (subpanels, heating systems etc) I wouldnt use the range or dryer thats for sure. You may have a loose connection somewhere or maybe your 2 legs arent balanced and more current is flowing through your right leg. You may need a service upgrade. It could be a number of things Again these are just possible scenarios that a licensed electrician will (should) be able to figure out. Dont hire an electrician under the table, make sure you get documentation, or a billing statement of work done, so if he says it is safe, he has to honor that. Best of luck, Rich |
#26 |
Eibwen
Check this out....
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07036.html I notice some of the larger breakers in the picture dont have the white amperage letters on the levers. May be some/all are truely defective from Chinar... [imagine that] |
#27 |
This question is for the pros.
Is the anti - oxident compound supposed to prevent this type of connection failure ? Or does it look like the end was in poor shape or damaged putting it in ? While you may get away with replacing the breaker - it looks the the wire is also going to have to be replaced too. I don't see how you can avoid calling an electrician. (Soon) |
#28 |
Anti-oxidant is just that. The problem with AL is that it expands and contract MUCH more than copper does with temp. fluctuations. I have personally retightened lugs that I installed initially with a torque wrench and was a bit dismayed at the difference a few months make.
There is a teenie weenie chance this is a POCO problem, but it is certainly sounding like a breaker. Andy |
#29 |
It is a compound that is used to prevent oxidation of aluminum wiring. You can tell when this is happening cause the wire will begin to turn green like the statue of liberty. However a corroding wire can cause connection failures and breakage. In the picture it appears his wiring is not corroding. It seems to be a heatbuildup that exceeds the rating of the awg. But yeah aluminum conductors do expand and contrast (creepage) which could loosen connections.
#30 | |
| Display Modes | |
| Dryer on the fritz.. wiring problem? | cisco10 | Electrical | 17 | 11-19-2009 02:26 PM |
| Complete AC installation in Old Capitol Hill Row House | jacko10 | HVAC | 0 | 09-18-2007 06:42 PM |
| Main Breaker Trips Repeatedly | kkf | Electrical | 7 | 06-18-2007 05:31 PM |
| Problem with ELECTRIC DRYER plugs | SpaceCrawler | Appliances | 6 | 06-03-2007 11:21 AM |
| Problem with Main Line or Not? | reibuild | Plumbing | 2 | 05-02-2007 11:41 AM |
