Unincorporated Des Plaines, IL - Chicago Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 01:36 AM   #1
Unincorporated Des Plaines, IL - Chicago code?
I bought a TH in unincorporated Des Plaines, and I'm not sure if I'm bound by Chicago electrical code? If not do I just follow NEC and be ok? My main project right now is running can lights in the living room where there is drywall (sections ripped out currently) on the ceiling, and basement (bare joists).
sativa is offline   Reply With Quote
Old 12-18-2012, 05:10 AM   #2
DIY staff
Rewards Points: 7,174
Call Cook county or go to their site and see what codes they use---
Old 12-18-2012, 10:28 PM   #3
Rewards Points: 826
Here is the code references. It's not that easy to read mind you....
http://www.sterlingcodifiers.com/cod...hp?book_id=561
curiousB is offline   Reply With Quote
Old 12-19-2012, 09:50 PM   #4
Rewards Points: 236
my understanding is that cRook co and chicago are the same, code wise. i used to live in cRook co.
Fix'n it is offline   Reply With Quote
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Installing 230V Outlet - Chicago - Code OakBehringer Electrical 5 07-13-2011 07:29 PM
Surface mounted switch leg code, chicago rollinhome Electrical 1 03-30-2011 10:12 AM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
