Ungrounded Wiring, Need Ground For Dishwasher - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 06:13 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by TTW View Post
See if there is a bare copper wire, about the thickness of a pencil, going into your main panel, or into your meter box outside and if there is, see if you can find where it or they originate.
Why would it be bare?
Old 12-07-2012, 06:18 PM   #17
Rewards Points: 1,548
Cheaper than insulated wire, and ground wires don't need insulation considering that they often run between exposed metal objects.
If a ground wire is insulated, the insulation must be green in color.
Water meters and water heaters should have a #6* copper wire connected between the inlet and outlet pipes (if metal), with an appropriate clamp holding it on each pipe. Sections of metal plumbing not bonded (electrically connected) together because of a piece of plastic pipe in between should similarly be bonded.
* Larger if the building service is for more than 100 amps, I don't have the size table handy now.
Old 12-07-2012, 06:19 PM   #18
TTW
TTW's Avatar
Just what I usually see, but I was going to bring that up. In my house it is actually insulated and is black, but pretty obvious in my case at the water meter, as about 2 feet was stripped to jump around the water meter.
Anyhow, it would probably be a thick single wire going it's own little lonesome way...
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-08-2012, 09:25 AM   #19
Licensed electrician
Rewards Points: 1,884
Neither a bonding jumper or a GEC is required to be green if insulated.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
NJMarine (12-08-2012), stickboy1375 (12-08-2012)
Old 12-08-2012, 02:09 PM   #20
Rewards Points: 528
And when you are in crawl space look for any shut offs or pressure regulators etc in water line, where that pipe comes into home.They need to be jumpered also.. Main GEC must be within 5ft of where pipe enters crawlspace ..picUngrounded wiring, need ground for dishwasher-imag0201.jpg
hidden1 is offline   Reply With Quote
Old 12-08-2012, 04:34 PM   #21
Rewards Points: 4,796
I think that's a moot point since there have been PEX repairs. And as for for the GEC in the first 5 feet, as I said there's nothing within 20 feet (up to the shut off valve for the house.)
jeffnc is offline   Reply With Quote
Old 12-08-2012, 04:40 PM   #22
TTW
TTW's Avatar
I have asked you several questions that you have not answered.
I have posted pictures of what is required.
It sounds like you have some serious grounding issues. If you ever get a lightning strike very bad things are bound to happen.
You really need to get an electrician in to check all of this out for you.
Old 12-08-2012, 08:44 PM   #23
I've responded to a number of your comments, even though I don't see a single question in any of your posts. I haven't had time to look in the crawlspace again to see what's coming out of the panel.
This isn't my house, so when the homeowner asks me why he needs an electrician at his expense to do so simple a thing as hooking the dishwasher back up, I want to have a good answer for him. I'm doing painting and tile work in the house.
Old 12-08-2012, 08:51 PM   #24
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
A good answer would be that you are not an electrician and this isn't a simple reconnect due to the lack of proper grounding.
Old 12-08-2012, 08:58 PM   #25
I can handle how I answer the question to him, thank you. I'm just looking for the information. The more I learn, the better, even when dealing with an electrician when I have to.
Old 12-08-2012, 09:23 PM   #26
k_buz's Avatar
HMMMM
As a side note: I find it to be an insult to all the true electrical contractors out there when a handyman (not meant to be offensive) comes to a DIY site to get information to use to profit off of... and yes, it is different when a homeowner comes here to ask for advice on their personal property.
Old 12-08-2012, 09:29 PM   #27
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If youre worried about it being grounded why not install a gfi in an accessable location like under the sink and use an appliance cord on the dishwasher to connect it?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-08-2012, 09:38 PM   #28
Originally Posted by k_buz View Post
HMMMM
And how am I profiting off of this exactly? Counting my time spent here and in his crawlspace, pay me even $10/hr and I'm down about $30 so far.
If it makes you feel better, I'm passing on the information to the homeowner so he can decide if he wants to do the work or hire an electrician to do it.
Not only do I not find it insulting, I find it wonderful that we have a site like this on which to share information for any purpose. Not to mention the fact that homeowners are listening in on the answers, which still makes this thread valuable for them. But again, if it makes you feel better, just don't answer any electrical questions when you see my name.
Old 12-09-2012, 09:00 AM   #29
E2 Electrician
That would still be a code violation in this scenario... 250.114 requires a dishwasher to be grounded.
Old 12-09-2012, 09:48 AM   #30
plummen's Avatar
If youre not opening the walls to replace wiring I think it would be very hard for an inspector to enforce that on an existing appliance.
Most of our inspectors around here anyway are smart enough to draw the line on existing equipment.
And if hes worried about it from just a safety stand point Id say the gfi would make it much safer than it being on a regular ungrounded outlet anyway
Wiring and using a common ground jnahman Electrical 9 07-09-2012 09:53 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
home grounding problem smoke-wagon Electrical 7 06-25-2009 03:07 PM
