Ungrounded Recpt. For Computer Use - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 07:33 PM   #1
Rewards Points: 115
ungrounded recpt. for computer use
Any concerns with adding a gfci recpt. in place of an ungrounded one to be used primarily for lap top use? It is very difficult to run a new grounded recpt. to this location. Thanks for any input.
pokey is offline   Reply With Quote
Old 10-14-2012, 07:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
No, but it will not be grounded.
jbfan is online now   Reply With Quote
Old 10-14-2012, 08:30 PM   #3
kevinp22's Avatar
Rewards Points: 252
and dont bother with a surge protector. its useless without a ground
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
mpoulton (10-15-2012)
Old 10-15-2012, 03:08 PM   #4
Rewards Points: 115
Appreciate the info. Thanks
Old 10-15-2012, 04:28 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Does your laptop even need a ground? I doubt it.
Old 10-15-2012, 05:24 PM   #6
Master Electrician
I haven't had a laptop charger in ages that didn't require a ground.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-15-2012, 05:26 PM   #7
E2 Electrician
I use all macs, they don't require a ground...
Old 10-15-2012, 06:40 PM   #8
Rewards Points: 266
My Mac chargers have classic three-prong plugs.
ionized is offline   Reply With Quote
Old 10-15-2012, 06:42 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
In most laptop chargers, the DC output is isolated from the AC....hence, even if grounded, the only part 'protected' is the AC/DC converter portion...the dc to the laptop is floating.
Old 10-15-2012, 09:42 PM   #10
Master Electrician
It may be useless bit the doesn't change the fact he's got a three prong plug and a two prong receptacle.
Old 10-18-2012, 03:14 PM   #11
Rewards Points: 115
Thanks for all the responses. This is not for my use but the user sometimes plugs a regular computer in this outlet with a three prong adaptor. I thought a gfci would offer better than nothing protection. I will eventually run a circuit with a clean ground. Some lap tops have two prongs and some have three so I am not really sure of possible issues. This one has two. Thanks again to all.
Old 10-18-2012, 03:49 PM   #12
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
It is perfectly acceptable to replace a two prong receptacle with a GFCI. Mark it "no ground."
John
jrclen is offline   Reply With Quote
Old 10-19-2012, 07:31 AM   #13
Rewards Points: 3,130
Really? Neither of my two laptop's chargers has a three-prong plug.
Old 10-19-2012, 08:21 AM   #14
jrclen's Avatar
Rewards Points: 514
I have three and the newest one has a three prong.
John
Extending ungrounded wire to new panel speedster1 Electrical 1 08-03-2012 10:40 PM
Best way to upgrade ungrounded outlets to grounded? mikemcd Electrical 5 09-12-2011 09:58 PM
Fixing ungrounded 3-prongs carlosjoan91 Electrical 9 01-23-2011 10:11 PM
Ungrounded Service klaus135 Electrical 2 01-23-2011 10:28 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
