Ungrounded Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 03:36 PM   #16
Rewards Points: 664
Originally Posted by parman View Post
This method is a NEC code accepted method of using 3prong receptacles without a grounding conductor.
But this will NOT make the inspector's tester say the outlets downstream are grounded right? I bought the same tester and I want to go around the house and do the same things he will do again.
crescere is offline   Reply With Quote
Old 08-29-2012, 03:42 PM   #17
Honestly, I am not sure. I have never tested a receptacle that was fed from the load side of a GFI to see if it reads ground.
My educated answer is no, it will not make the inspectors tester say the outlets downstream are grounded.
As I said earlier, that does not matter if you have a NEC approved method of using 3-prong receptacles on an ungrounded circuit. (unless there is a local ordinance against this).
parman is offline   Reply With Quote
Old 08-29-2012, 03:49 PM   #18
Licensed electrician
Rewards Points: 1,028
Adding GFI protection upstream of a 3 prong receptacle will not provide or show as grounded. A three lite tester will not trip the upstream GFI either.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
jbfan (08-29-2012), stickboy1375 (08-29-2012)
Old 08-29-2012, 06:27 PM   #19
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
And this will surely get written up on most if not all H-I reports.
Best way to upgrade ungrounded outlets to grounded? mikemcd Electrical 5 09-12-2011 10:58 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
Ungrounded outlets white29 Electrical 2 05-31-2010 03:31 PM
Ungrounded outlets RJ75 Electrical 13 04-05-2009 07:51 PM
apartment: 3-pronged, ungrounded outlets pro_DIYer Electrical 9 10-15-2008 05:22 PM
