Ungrounded Bath Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 04:54 PM   #1
ungrounded bath fan
I just installed a bath fan on an ungrounded circuit. Was this a dumb thing to do, and could I remedy this by hooking up a GFCI outlet on the circuitry leading to the bath fan. I had an electrician say that a GFCI outlet would not help an ungrounded circuit, but i seem to read elsewhere that it could work.
skillet is offline   Reply With Quote
Old 11-07-2011, 05:00 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
The electrician is wrong. Is he really an actual electrician? GFCI protection can be used instead of a grounding conductor to retrofit old wiring. The grounding conductor has nothing to do with the functionality of a GFCI.
mpoulton is offline   Reply With Quote
Old 11-07-2011, 09:52 PM   #3
Ditto to mpoulton's post. A GFCI checks for a differance in current flow between the hot and neutral, it does not require a ground to work.
hayewe farm is offline   Reply With Quote
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 04:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
