Unfused Connectors MELTED House Wires WHAT TO DO??? - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 04:10 PM   #61
Megger Test
Hello, You seem to know about megging circuits. I have an Amprobe 45 digital meggar and I have to meg a house that was hit with high voltage. a 4800 volt utility line came down and hit the messenger line to the home. Several wires burned up and of course it melted the electrical panel. I want to meg the branch circuit wiring in the home that I cant see behind the walls and ceilings. I know I have to perform the meg test but I am a little unsure on how to actually use the megger correctly.
I know I have to disconnect everything in the house and turn on light switches and remove bulbs. Do I disconnect all of the grounds and neutrals from the panel and then connect the leads to hot-neutral, than neutral-ground, then hot-ground wire. Do I then send 1000 volts setting on meggar through the wiring. I am lost at what a good ohm reading should be. Can you help me figure this out?
hastime is offline   Reply With Quote
Old 02-12-2009, 05:17 PM   #62
If you don't know how to use it, why would you be using in someone's house?
jerryh3 is offline   Reply With Quote
Old 02-12-2009, 06:25 PM   #63
Meggar
I know how to use it but am unsure what the readings should be, it is not in milliamps but OHMS. Everybody has a different opinion on the correct way to test the integrity of the romex. I was looking for an explanation to make sure I do it correctly.
Old 02-12-2009, 07:01 PM   #64
WOW, glad no-one was hurt
I use a rubber pad across the main lugs when I'm in the panel
Covers them completely, I was thinking it was just being overcautious
Now I know its a good thing
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 05:05 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
