Underwater Elec. Panel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 11:28 AM   #31
An old Tradesmen
Rewards Points: 7,794
Don't worry about the paper burning.
Worry about the toxic fumes the PVC jacket gives off when it burns.
Old 11-02-2008, 06:39 AM   #32
Licensed Electrician
Originally Posted by SD515 View Post
Water itself in a pure(r) form is not very conductive. It's the contaminants that water may contain that become the conductive particles within water. 7 feet of water in a basement is surely to have 'foreign contaminants' that can be conductive, but apparently the concentration wasn't enough to create a low enough resistive path for the panel to short out.
This was interesting to me because my son's science project last year was on how different minerals affect the conductivity of water (an electrician's son doing an electrical science project.....go figure). Anyway, distilled water in of itself had a very low conductivity in comparison to distilled water that had been mixed with various minerals.
I once worked on a remote hydroelectric project that had it's own batch plant, quarry, and crusher plant. The quarry had many 480 volt discharge pumps in sump areas for getting rid of influent water. The combination starters for the pumps were above the sumps. We lost the power feed to a section of the pumps and they stopped, but the remainder of the pumps kept chugging happily on...with the starters under 10+ feed of water.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 11-02-2008, 08:06 AM   #33
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
I have found one of the biggest misconceptions, to the lay person and some electricians, is that water itself is a good conductor of electricity.
Old 11-02-2008, 04:38 PM   #34
While scuba diving I have used a regular battery operated lantern for under water use!
Electrons prefer to take the path of least resistance back to its source. They don't scatter like dust blowing in the wind!
Now, where you get into trouble with electrons, is if you are the path of least resistance. If they flow through your body, it will only take a few milliamps to stop your heart. And not many more to poach the white corpuscles in your blood.
Electrons won't flow through distilled water either! The water must have contaminates, in order to pass along the electrons.
If the water in your flooded basement were as pure as distilled water, all you would have to do, would be to wait until all is dry.
Unfortunately, the contaminates are what will cause everything to corrode.
And this happens really fast!
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
