Underwater Elec. Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 10:22 AM   #16
Rewards Points: 1,062
in which location was this, BTW ?
Old 10-31-2008, 11:14 AM   #17
what is BTW?
robin power is offline   Reply With Quote
Old 10-31-2008, 11:40 AM   #18
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
Originally Posted by robin power View Post
what is BTW?
By The Way
jbfan is online now   Reply With Quote
Old 10-31-2008, 11:49 AM   #19
I thought you meant in which location of the house. Sorry. the flooding was northern Illinois, Cook County
Old 10-31-2008, 01:33 PM   #20
DIYer
I would worry about galvanic corrosion on anything that was live. If you see any copper that looks green or scaly or slimy it needs to be addressed.
Gigs is offline   Reply With Quote
Old 10-31-2008, 02:13 PM   #21
RippySkippy's Avatar
Originally Posted by KE2KB View Post
I cannot say much about the wicking properties of the paper used in NM cable. A simple experiment could give you that answer. Take a length of NM, and put one end (several feet) of it under water for a few days. The, cut it open, and see how much got wet.
Even if it did get wet, you won't get a short, since the plastic insulation will not be penetrated. I cannot say what would happen over time though.
The reason I was asking this is because this summer central Iowa swamped also, one of the news programs was talking with a HO that was taking them through the rebuild process...and that's one of the things the city inspectors were telling everyone. I had not heard of this either...it makes some sense....I was just wondering if there was a standard protocol and thought some of the pro-sparkys here could share their thoughts.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-31-2008, 02:21 PM   #22
Rewards Points: 894
Actually, I've always wondered why paper is used in NM cable. Why use something that's actually flammable?
I think the purpose of the paper is to keep the wires from rolling over each other, and keeping the cable more or less flat, easier to pull?
But I would prefer some kind of plastic over paper. Then, paper has been used ever since NM cable came along, so it must not be an issue with fire.
Not all that much of an issue with getting underwater either I guess.
Ultrarunner2017 is offline   Reply With Quote
Old 10-31-2008, 06:34 PM   #23
mis
andy from england
seems i was too late to reply to your problem,hope its not going to hit your wallet too much ethier way water and electric does't mix best to be on the safe side but you should't have rewire your home just a dry out should do as long as you earth line not efected
andrew.s.gill@btinternet. is offline   Reply With Quote
Old 10-31-2008, 06:57 PM   #24
Rewards Points: 894
Think of an old-fashioned vaporizer which used two electrodes inside a plastic/bakelite tube, with a small hole at the bottom for water to enter, and a larger one at the top to allow steam to escape.
The vaporizer would usually draw between 3 and 5 Amps, but if you were to add salt to the water, it would draw much more, and eventually trip the breaker / blow the fuse. If you have very soft water (few minerals) you would need to add salt to the vaporizer to get it to generate enough steam.
I would expect most of the current from the submerged panel to flow through the water in the immediate area of the panel, between buses or from one bus to ground. There wouldn't be much current through the load breakers, and not enough through the main to trip it.
A GFCI breaker would probably trip, since there would most likely be an imbalance of current between hot and neutral.
Old 10-31-2008, 09:28 PM   #25
kbsparky's Avatar
....But I would prefer some kind of plastic over paper....
Then you should specify and install type UF cable, instead of using NM. All plastic, no paper.
Old 10-31-2008, 10:57 PM   #26
Rewards Points: 894
Well, I may be a bit on the obsessive side, but I'm not on the wealthy side<g>!
I really used to hate working with UF. It was soooo hard to strip the outer jacket.
Now, so much easier
Old 11-01-2008, 06:34 AM   #27
An old Tradesmen
Rewards Points: 7,356
Water, does not conduct electricity.
Its the minerals in the water that conduct.
The reason you can be electrocuted in a tub or shower is.
A. the water isn't distilled.
B. It only takes a few milli amps to electrocute a person.
Old 11-01-2008, 10:32 AM   #28
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by SD515 View Post
Water itself in a pure(r) form is not very conductive. It's the contaminants that water may contain that become the conductive particles within water. 7 feet of water in a basement is surely to have 'foreign contaminants' that can be conductive, but apparently the concentration wasn't enough to create a low enough resistive path for the panel to short out.
actually water, in its pure form is not conductive at all. It is the mineral in the water that carry the current.
Saw a seminar from where the presenter drank from a glass of water with a hot wire in the water as he held the neutral. Very well purified water.
Old 11-01-2008, 10:38 AM   #29
nap
You talking to me?
nap's Avatar
AC cable also uses paper as a wrap as well. Paper is often an excellent insulator (obvioulsy as long as designed as such without other non-inusulating contaminants within). It just isn't very durable.
as to flammable; paper can be treated so as to make it quite non-flammable. Don;t know if the paper in NM or AC is treated as such but do you have any idea what the temp required to initiate fire in paper is? It is quite high. If the wire is that hot, the paper is not your only worry. Ther plastic insulation would have melted long before and the paper may be the only thing preventing a short circuit.
Old 11-01-2008, 10:46 AM   #30
the Musigician
DangerMouse's Avatar
i pulled some paper from a scrap of NM, it burns..... good point on the paper being the only...etc.!!!
DM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
