Understanding How To Size A Circuit Conductor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 03:58 PM   #1
DIY
Rewards Points: 150
Understanding how to size a circuit conductor
Let's say I have a device, a time machine perhaps, that I will be hard wiring into my panel with it's own breaker. On the label, next to where it says "1.21 gigawatts", it says that minimum ampacity is 52 amps and maximum circuit breaker size is 60 amps.
Per the NEC, which of those numbers (beside 1.21 gigwatts ) should I use to determine conductor gauge, and why?
gp_wa is offline   Reply With Quote
Old 09-09-2008, 04:03 PM   #2
Electrician
Is this really just an AC unit?
chris75 is offline   Reply With Quote
Old 09-09-2008, 04:16 PM   #3
DIY
Rewards Points: 150
No it's a time machine :D
I'm trying to keep it general by not actually telling you what it is. If it matters, then I'm hoping that will just be part of the answer.
Old 09-09-2008, 06:10 PM   #4
DIY Junkie!!
Rewards Points: 180
I suppose it would depend on the vertical rebound index of the flux capacitor, wouldn't it ???
Dugly
YerDugliness is offline   Reply With Quote
Old 09-09-2008, 06:28 PM   #5
Circuit/breaker sizes go from 50 to 60 amps.
52 is greater than 50 so do the math. #6
When you get it up and running, find me when I'm about 10 years old and tell me to move to Seattle and befriend a "Mr Bill Gates".
Give John Lennon a heads up too.
220/221 is offline   Reply With Quote
Old 09-09-2008, 06:39 PM   #6
DIY
Rewards Points: 150
Do the math on which number? 52 or 60?
Old 09-09-2008, 07:06 PM   #7
DIY
Rewards Points: 150
No, this is a newer model, well actually an older model, it gets confusing with these things. Anyway, they switched to a linear dual axis rebound index after (I mean before) some guy got turned into a newt. It'll be in the news twelve years ago.
Old 09-09-2008, 08:01 PM   #8
Use awg #6 fused at 60 amps
Mightyidi is offline   Reply With Quote
Old 09-09-2008, 08:04 PM   #9
Edited:
Circuit/breaker sizes go directly from 50 to 60 amps
Old 09-09-2008, 08:18 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
It certainly DOES matter what it is. A/C's, motors and welders all have dedicated sections in the code and follow certain rules. Time machines do not have this luxury.
Old 09-09-2008, 09:18 PM   #11
DIY
Rewards Points: 150
Edited:
You're missing my question. I am asking which number is of relevance to this calculation, 52 (minimum ampacity), or 60 (maximum protection).
I understand why you'd use a 60 amp breaker as apposed to a 52 amp one...
Old 09-09-2008, 09:21 PM   #12
DIY
Rewards Points: 150
If it has a motor, does that have a bearing on which of the two numbers I've asked about are relevant?
I thought that the difference was between continuous and intermittent rating, and that a continuous rating changes the wire gauge needed for a particular amp rating.
In other words, a heat coil drawing 50 amps might require #6 wire, while a motor drawing 50 amps might require #5.
Old 09-09-2008, 09:30 PM   #13
In your case, 52MCA & 60 Max OCPD, the answer is still 60A and #6.
Old 09-09-2008, 09:32 PM   #14
DIY
Rewards Points: 150
My case, assuming what? (sorry) A/C, motor, welder, none of the above?
Old 09-09-2008, 09:40 PM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If your time machines factory nameplate says minimum ampacity 52 amps then you need to size the conductor based on that amperage. Which would be a #6 awg copper conductor or one with a higher ampacity. The max breaker is just that 60 amps maximum. You can't use a 50 because it is not sufficient for the load served. As said several times there is not a 55 amp breaker so next protection size after 52 amps is 60. Motors are 1.25 times the largest plus the sum of the rest, if a single motor then 1.25 times the flc of that motor. If the equipment is a continuous load (will be operating for 3 hours or more) then it is 1.25 times the rated ampacity of that equipment. If however a nameplate states minimum ampacity then continuous or whatever has already been factored in and the equipment must be served with conductors that have at least that minimum ampacity.
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
Direct Burial Conductor Size jrepp Electrical 9 12-21-2007 03:30 PM
Transformer Help chcustom Electrical 28 12-10-2007 11:40 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
