Understanding Circuit Pannel And Single Pole Vs. Double Pole Circuit Brakers - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 08:07 PM   #1
Question
Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers
I have a 100amp GE circuit braker service.
At the bottom of the pannel shown on the diaghram, I can use slim type circuit breakers. But those two buttom positions are now occupied by double pole circuit breakers (One for AC Handler and the other one for the AC outside, 15 and 30 AMPS respectively). My question is. Can I re-install these two buttom breakers up to slots the ones that do not accept thin type breakers? or does those breakers need to stay where they are for some reason?.
grisha_1 is offline   Reply With Quote
Old 01-30-2009, 09:33 PM   #2
What is the model number of your panel?
Willis
williswires is offline   Reply With Quote
Old 01-30-2009, 10:51 PM   #3
Wink
It's GE TM1610S
Old 01-30-2009, 10:52 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Maybe....it depends on whether the double pole breakers are THQP's or THQL's. If they are THQL's full space double poles then yes they will move anywhere in the panel. If they are two slim 1/2" handle tied THQP's they cannot be installed on a bus stab that does not have side tabs. Look at the image below.....
THQP
THQL
The image below should be similar to your panel. Notice the side tabs on the bus bars and the two upper bus stabs that do not have them. 1/2" THQP's install on the stabs with side tabs. They will not fit on the two upper bus stabs. But full size 1 " THQL's will install anywhere in the panel. A double pole 1/2" THQP must contact two tabs on different bus stabs, so the panel below will take 8 double pole THQP's.
Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers-ge-100-amp.jpg
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-31-2009, 07:40 AM   #5
Thanks a lot Stubbie... That's the answer I was looking for...
Tags
circuit breakers
