-   -   Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers (http://www.diychatroom.com/f18/understanding-circuit-pannel-single-pole-vs-double-pole-circuit-brakers-37223/)
grisha_1 01-30-2009 08:07 PM
I have a 100amp GE circuit braker service.
At the bottom of the pannel shown on the diaghram, I can use slim type circuit breakers. But those two buttom positions are now occupied by double pole circuit breakers (One for AC Handler and the other one for the AC outside, 15 and 30 AMPS respectively). My question is. Can I re-install these two buttom breakers up to slots the ones that do not accept thin type breakers? or does those breakers need to stay where they are for some reason?.
williswires 01-30-2009 09:33 PM
What is the model number of your panel?
grisha_1 01-30-2009 10:51 PM
It's GE TM1610S
Stubbie 01-30-2009 10:52 PM
1 Attachment(s)
Maybe....it depends on whether the double pole breakers are THQP's or THQL's. If they are THQL's full space double poles then yes they will move anywhere in the panel. If they are two slim 1/2" handle tied THQP's they cannot be installed on a bus stab that does not have side tabs. Look at the image below.....
THQPhttp://ecx.images-amazon.com/images/...500_AA280_.jpg
THQLhttp://www.aplussupply.com/break/ge/thql2.jpeg
The image below should be similar to your panel. Notice the side tabs on the bus bars and the two upper bus stabs that do not have them. 1/2" THQP's install on the stabs with side tabs. They will not fit on the two upper bus stabs. But full size 1 " THQL's will install anywhere in the panel. A double pole 1/2" THQP must contact two tabs on different bus stabs, so the panel below will take 8 double pole THQP's.
grisha_1 01-31-2009 07:40 AM
Thanks a lot Stubbie... That's the answer I was looking for...
