Old 02-11-2013, 05:05 PM   #1
Is underpowering a Power Distro bad?
Hi everyone,
I'm looking for some advice here. I have a 120 amp Power Distro that I am using to power a soundsystem in a theater. I usually connect it to more than adequate amperage to work efficiently. My question is, if I only have a 100 amp circuit to connect it to, will that hurt the power distro or anything else? The chances of actually using all 120amps is extremely slim, maybe 80 amps tops.
Here is the unit.
http://www.furmansound.com/product.p...=01&id=ASD-120
Thank you.
calebingersoll is offline   Reply With Quote
Old 02-11-2013, 06:37 PM   #2
Semi-Pro Electro-Geek
You only need to connect it to a source capable of powering the actual load. The maximum load you could use is 120A, but your actual load depends on what is being powered. So calculate the total load or measure the current in operation, and make sure only to use it with supplies that exceed that load.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-11-2013, 07:12 PM   #3
Originally Posted by calebingersoll View Post
Hi everyone,
Here is the unit.
Thank you.
NO !
If you are sure that the load will not exceed 100 amps.
then all will be fine.
I am not sure what code say's thou !
dmxtothemax is offline   Reply With Quote
Old 02-11-2013, 07:21 PM   #4
For a proper feed, the first thing you will notice if you draw too much power is that you will trip a breaker.
Since you know that the reason was operating too much equipment, you should immediately cut down on the power you are drawing. In the case of modern audio equipment, the louder the sound and the more bass you produce, in general, the greater the power draw. It is not good to push the system so as to frequently and repeatedly trip breakers. (You can wear out the breakers that way and you would also be overheating the wiring.)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 02-11-2013, 08:22 PM   #5
Missouri Bound's Avatar
After looking at the specs, it can only be wired for up to 100amp. since the maximum wire size is #2. Is this a dbl pole breaker you hook it up to? How is it configured?
Do you want it your way or the right way?
Old 02-11-2013, 08:37 PM   #6
Licensed Electrician
k_buz's Avatar
This is what makes me question this product's legality...
Safety Agency Listings:All current-carrying components are NRTL-C TUV listed.
This doesn't mean that this piece of equipment is listed.
Location...Location...Location
Tags
amps, distro, power
Event Production power distribution, I want to do it right. mattvivsound Electrical 0 07-13-2012 09:54 AM
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
