-   -   Is underpowering a Power Distro bad? (http://www.diychatroom.com/f18/underpowering-power-distro-bad-171703/)
calebingersoll 02-11-2013 04:05 PM
Hi everyone,
I'm looking for some advice here. I have a 120 amp Power Distro that I am using to power a soundsystem in a theater. I usually connect it to more than adequate amperage to work efficiently. My question is, if I only have a 100 amp circuit to connect it to, will that hurt the power distro or anything else? The chances of actually using all 120amps is extremely slim, maybe 80 amps tops.
Here is the unit.
http://www.furmansound.com/product.p...=01&id=ASD-120
Thank you.
mpoulton 02-11-2013 05:37 PM
You only need to connect it to a source capable of powering the actual load. The maximum load you could use is 120A, but your actual load depends on what is being powered. So calculate the total load or measure the current in operation, and make sure only to use it with supplies that exceed that load.
dmxtothemax 02-11-2013 06:12 PM
Originally Posted by calebingersoll (Post 1115128)
Hi everyone,
Here is the unit.
Thank you.
NO !
If you are sure that the load will not exceed 100 amps.
then all will be fine.
I am not sure what code say's thou !
AllanJ 02-11-2013 06:21 PM
For a proper feed, the first thing you will notice if you draw too much power is that you will trip a breaker.
Since you know that the reason was operating too much equipment, you should immediately cut down on the power you are drawing. In the case of modern audio equipment, the louder the sound and the more bass you produce, in general, the greater the power draw. It is not good to push the system so as to frequently and repeatedly trip breakers. (You can wear out the breakers that way and you would also be overheating the wiring.)
Missouri Bound 02-11-2013 07:22 PM
After looking at the specs, it can only be wired for up to 100amp. since the maximum wire size is #2. Is this a dbl pole breaker you hook it up to? How is it configured?
k_buz 02-11-2013 07:37 PM
This is what makes me question this product's legality...
Safety Agency Listings:All current-carrying components are NRTL-C TUV listed.
This doesn't mean that this piece of equipment is listed.
