Underground Wiring To Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2009, 09:49 PM   #1
Smile
Underground wiring to pump
I need to run an electrical line from the 200amp meter to a 230V well pump. The distance from the meter to the well is 800ft. I have several questions that I hope I can get some help on.
1. I'm wondering what is a better type of installation for this distance. Running conduit and installing the wire or installing direct bury wire?
2. Which is cheaper - direct bury or Conduit installation
3. what size wire will I need for direct bury to run that distance and carry the needed voltage?
4. what size wire will I need for the conduit installation to run that distance and carry the needed voltage?
5. What depth do I need to install the conduit if I run the line on my property. I'm in Florida.
Thanks in advance for any information !!!
rolltested is offline   Reply With Quote
Old 04-27-2009, 10:27 PM   #2
Conduit is always better because stuff happens. 18" depth.
800 feet is a long ass trench
Here is a voltage drop calculator. Find out the amperage on your pump and plug it in. It looks like #4's will carry a 10 amp load 800 feet with a voltage drop of only 2%
#6's will lose over 3% and that is a touch too much IMO.
http://www.electrician2.com/calculat...r_initial.html
220/221 is offline   Reply With Quote
Old 04-27-2009, 10:32 PM   #3
Electrical Contractor
kbsparky's Avatar
CHECK the rating of that motor. Many motors which are rated at 230 Volts, are also compatible with a 208 volt supply. You may have to ask the manufacturer.
If that is the case, your wire size may not have to be increased as much.
Another option would be to install a buck/boost transformer instead.
Old 04-27-2009, 10:39 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Before I can able give the answer here need to know what size pump motor the reason why it will affect the slection of conductor size.
800 Foot is pretty long run there.
Merci,Marc
Old 04-27-2009, 10:40 PM   #5
For a 10 amp motor I think #6's would be OK, It's still well with in the operating range for almost any 10 amp motor.
Last edited by hayewe farm; 04-29-2009 at 12:02 AM. Reason: Spelling-added load specification
hayewe farm is offline   Reply With Quote
Old 04-27-2009, 10:58 PM   #6
Rewards Points: 2,350
Set a meter out at the pump house. The extra cost of the metering charge is nothing compared to the pipe, wire, and labor required to power it from the house.
Old 04-28-2009, 12:49 PM   #7
Rewards Points: 58
Originally Posted by hayewe farm View Post
I think #6's would be OK, It's still well with in the operating range for almost any motor.
What if the motor is 50 hp. How can you make a judgement call like that when you have no idea what he has. #6 could very well be to SMALL.
"It's still well with in the operating range for almost any motor".
What?????????
Old 04-28-2009, 06:57 PM   #8
IMO it is not a wise advise you just quoted here.
as few members here are very sharp they will withhold the answer until the OP give the motor size that is the key word that will really affect the conductor sizing espcally with that kind of distance.
Merci,Marc
Old 04-28-2009, 11:58 PM   #9
Sorry I was using the 10 amp load that 220/221 was using but failed to specify such. Have edited my post to correct that.
Old 04-29-2009, 12:05 AM   #10
Oh and thanks to both of you for catching that rather stupid error.
Old 04-29-2009, 12:15 PM   #11
Rewards Points: 58
Hayewe, No problem. We all make a bad sometimes.
Tags
electrical , pump , size , underground , wire
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 08:42 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 10:09 PM
pump wiring konafixits Electrical 23 07-07-2008 10:55 AM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 08:30 PM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 06:50 PM
