Underground Wiring For Distances - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 05:28 PM   #1
underground wiring for distances
I have a temp hydro tower in at my lot line, but my house and garage are 450 to 500 ft from this hydro tower. What do I need in terms of underground wire size to take me to my garage where I am going to have my main box (I plan on having a welder and various tools there) and from there to a 100 amp circuit in a house I am building. How deep do I have to dig my trench and should I encase the wiring in PVC?
ClarenceD is offline   Reply With Quote
Old 01-09-2011, 06:33 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
here is a calculator to figure out length. Bury depth is directly related to whether or not you are using PVC and may vary by local code
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
ClarenceD (01-10-2011)
Old 01-09-2011, 07:58 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
what is a hydro tower?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-09-2011, 08:04 PM   #4
Master Electrician
Rewards Points: 3,812
I think it must be a transformer or distribution point.
brric is online now   Reply With Quote
Old 01-09-2011, 09:12 PM   #5
Rewards Points: 330
he is in canada.power pole.
oleguy74 is offline   Reply With Quote
Old 01-09-2011, 10:04 PM   #6
Rewards Points: 1,494
Several utility companies have "Hydroelectric" in their names. But I have not heard of a pole referred to as an edison tower given that several other utility companies have "Edison" in their names e.g. Boston Edison (now NSTAR) and Consolidated Edison or Con-Ed.
When you mentioned tower I did not think any customer is hooked up at a metal high tension transmission line tower.
You may need to have a medium tension (distribution voltage; primary voltage) line brought onto your property to perhaps 50 feet from the house and a transformer installed there. Then run the 120/240 volt line to your house and garage.
Running 120/240 for 200 amps the full 500 feet requires mighty fat wires. The calculator gave me 750 mmca (square millimeters cross section?) copper wire. 750 sq. mm is slightly more than one inch square.
At distribution voltage (typically 7000 to 15000 volts) your up to 200 amps @ 240 volt household draw is less than 8 amps. The power company probably has a minimum wire size, say, 8 gauge, that it will string on poles or through a trench. If you dig the trench yourself, of course the amount the POCO will charge you for the hookup will be less.
underground wiring Darnoldi Electrical 2 11-08-2010 10:51 PM
All wiring underground, yet power outage...? PCMLR Electrical 2 10-10-2010 10:20 PM
Underground Wiring From House to Garage Virginhomeowner Electrical 7 05-21-2010 10:53 PM
Outbuilding wiring and underground wiring questions tpagel Electrical 7 07-08-2008 08:38 AM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 07:58 AM
