Underground Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 11:00 AM   #1
Question
underground wiring
Hello, I need to run a #2 awg 3conductor wire from a 200 amp sub-panel to a 75 amp panel the distance is 600 ft. and the wire will be buried in conduit. First of all is the #2 wire big enough and if so where can I purchase 600 ft. all I can find so far is 500 ft. rolls. Thanks
oldman56 is offline   Reply With Quote
Old 06-24-2009, 11:11 AM   #2
DIY'r
ScottR's Avatar
Are you looking at #2 Cu or Al?
For #2 Cu, you'd have a 7% voltage drop @ 600ft @ 240V @ 75A. If you're planning on drawing at or near 75A you'll need larger wire.
I'm getting 4/0 Cu for a <3% drop at 240V/75A and 600ft, but that's on an internet calculator, so hopefully someone will check my numbers.
ScottR is offline   Reply With Quote
Old 06-24-2009, 11:27 AM   #3
Where can a 4/0 wire be purchased?
Old 06-24-2009, 01:47 PM   #4
DIY'r
ScottR's Avatar
Not sure where the wire can be purchased in your area specifically, but you should check out electrical supply houses. You can probably get custom lengths online, but shipping will be high.
I saw you opened up another thread about 4/0.. You should wait until someone confirms what I said about sizing the wire before you buy it based on my advice.
Also, I should have said earlier that Al wire will be much less expensive for that run, even though you would need a larger size.
This is the calculator I was using, BTW:
http://www.southwire.com/voltagedropcalculator.jsp
Old 06-24-2009, 02:38 PM   #5
No need for 2 threads about the same thing
Here's the other thread:
#4/0 awg wiring
Old 06-24-2009, 03:04 PM   #6
Sorry, I'm new to the site and I'm still learning, I will delete one if I figure it out. Thanks
Old 06-24-2009, 06:46 PM   #7
Electrical Contractor
kbsparky's Avatar
Try here.
-KB
Underground wiring job while landscaping tjfitzgerald Electrical 24 03-20-2009 07:22 PM
Outbuilding wiring and underground wiring questions tpagel Electrical 7 07-08-2008 08:38 AM
Running Underground wiring to shop 200Ft kola Electrical 5 06-06-2008 09:13 AM
Underground Wiring millipede Electrical 4 11-24-2006 10:00 PM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 07:58 AM
