Underground Wire For Outdoor Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 01:14 PM   #1
din
underground wire for outdoor lights
i want to run about 200 feet of wiring underground to put up some outdoor lights around our pond and i was hoping someone could help me choose the correct wire gauge to use.
thanks,
din
din is offline   Reply With Quote
Old 05-05-2009, 10:43 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
Depends on a number of factors. What voltage will these lights run on? How many lights? What is the wattage of the bulbs you will be using in these lights? If these are line voltage (120volt) are you going to be needing outlets at some or all of these lights?
theatretch85 is offline   Reply With Quote
Old 05-06-2009, 08:27 AM   #3
din
thanks, and here's some more details
it will be 110V and what i'll probably do is put a two-outlet receptacle near the pond where i can plug lights and whatever else i might want to plug in. i don't plan on using anything with too much wattage. right now i'm using three 50 foot extension cords plugged together and haven't had any problems.
Old 05-06-2009, 11:38 AM   #4
Rewards Points: 160
Conduit or direct burial? 200' is a fair distance and could be a factor in determining your wire size. Since you are using extension cords and they are not tripping breakers that is a good thing.
I would run #10 wire in PVC conduit to a weatherproof 4x4x"deep" box outside. Use a 20 amp single pole recept. Then you can use #12 for additional lights ect.....
The #10 wire will give you some room if you ever need it. And yes, it needs GFCI protection.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Copper wire sizing underground 185ft run 200A service DIYALLTHETIME Electrical 5 03-04-2009 08:22 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
burying wire underground amakarevic Electrical 42 03-16-2008 02:04 AM
