Underground Wire To Lamp Post - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 08:51 PM   #1
Rewards Points: 462
Underground wire to lamp post
Hi all!
Looking to run conduit for a future outdoor brick pillar which will have a lamp on top. This is a new construction so the rough grade is currently about 6 inches below what the final grade will be and I want to get this installed before the landscapers come with the top soil.
The electricians ran the wiring through the basement to the point where it will exit the house and go to the post and I am planning on doing the rest.
I did some searching online and found several different opinions on what to use for conduit. Does PVC have to be buried deeper than rigid metal conduit, and is standard rigid metal conduit suited for underground use?
I guess the question is, what should I use for conduit and how deep? The less digging I have to do the happier I am
Richo is offline   Reply With Quote
Old 05-20-2011, 09:10 PM   #2
joed's Avatar
Rewards Points: 12,872
18" deep. I would use the PVC. No worries about rusting out in future.
Old 05-20-2011, 09:46 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by Richo View Post
Hi all!
PVC, Schd 40 below, Schd 80 above or Schd 80 for both.
RMC is expensive and will rust out in 40 years, I think you can get it in AL, then it wouldn't rust. PVC is cheap, even schd 80 isn't that expensive and it never rusts, rots, etc.
No reason I can think of not to use PVC for anything underground residential.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 05-20-2011, 10:01 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
if protected by a GFI UF cable could be only 12"
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-20-2011, 10:04 PM   #5
Just call me Andrew
Rewards Points: 1,020
I'd put it on a GFCI, and run 3x THWN wires in PVC conduit 12" deep. That's what I did for my lamp post.
Andrew
secutanudu is offline   Reply With Quote
Old 05-20-2011, 10:06 PM   #6
Rewards Points: 1,016
Ditto - this is what I did to a fountain.
____________
Vince
Old 05-20-2011, 10:37 PM   #7
Rewards Points: 462
PVC sounds like the way to go.
I hope it's already on a GFCI breaker. The electricians installed a switch by the front door that feeds the wire in the basement that will eventually go to the light. There are 3 GFCI breakers in the main panel so I will have to test the wires to see if they are on one of those 3 circuits.
Thanks for your help
Old 05-20-2011, 10:39 PM   #8
Just call me Andrew
All you have to do is install a GFCI outlet on that line before it leaves the basement. Connect the light to the LOAD side of the GFCI outlet, then you are protected. Much cheaper than a GFCI breaker.
Andrew
Old 05-20-2011, 10:49 PM   #9
Rewards Points: 462
Definitely, and I actually have an extra GFCI receptacle laying around in a drawer that I can put to perfect use so it won't cost anything. Thanks for the tip!
Old 05-21-2011, 07:36 PM   #10
Rewards Points: 462
One more quick question... I have a length of 16/3 SOW cable that I bought years ago and I seem to recall being told that it was rated for contact with water, oil, etc. Is this wire up to code to use in underground conduit?
Old 05-21-2011, 07:51 PM   #11
No, not rated for use in conduit - it's used more like in a power cord senario.
Old 05-22-2011, 09:45 AM   #12
Electrician
SD515's Avatar
Rewards Points: 504
2 problems with your suggestion of using 16/3 SOW cord...(1) 16 gauge is less than the minimum required size of wire for any branch circuit wiring in a house (2) Cords cannot be used in place of a building fixed wiring system.
Kyle
Old 05-22-2011, 11:00 AM   #13
Rewards Points: 462
OK, thanks for letting me know.
Old 05-28-2011, 12:35 PM   #14
Rewards Points: 462
OK I picked up the PVC and I got one of these:
I will have to drill a hole in the foundation of the house to pass the PVC pipe through.
Where you see the gray below the siding, there is wood behind the plastic cover. There is actually a hole the foundation where a faucet was going to be but then it was moved due to that area being covered in soil. I am planning on using the existing hole for the PVC.
When I've seen one of the above PVC connectors on a house, it's always above ground. This will eventually end up being covered in dirt when the landscaping is done.
2 questions arise: Is this the wrong type of PVC connector for being below ground, and although this isn't exactly an electrical question, is standard exterior caulk going to be sufficient to keep moisture from seeping in where the PVC enters the building below ground?
Also, the home center had a specific type of cement for this PVC. I already have PVC primer and cement used for standard plumbing pipe. Is the glue I have not compatible with PVC conduit?
Any input is appreciated
Old 05-28-2011, 01:59 PM   #15
Scared Electrician
your glue is fine. this is not acceptable for underground, as it has to be accessible. If underground you need a 90. i would not use standard caulking
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Question about underground wire type Tmb9862 Electrical 9 11-26-2009 10:35 AM
Two Circuits in one Box? GFI for lamp post? Burbman Electrical 4 05-13-2009 03:59 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 02:39 PM
need to control remote lamp post timalabim Electrical 3 05-01-2006 10:40 AM
