Underground Service Wires Cut - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 02:12 PM   #1
Underground service wires cut
I bought a house that has a 60 amp service to an out building, while digging with an excavator,to inspect a wet spot in the yard, we cut the service wires to the building. Yes, I should have called the elec company first. What is the easiest way to fix this? The ground stays wet from a really small spring that seeps all the time. It is about 150 feet from the house, and has #4 wire. Would split bolts and some rubber and electric tape be enough?
Thanks for the help
Waverly
waverly guy is offline   Reply With Quote
Old 09-21-2010, 03:13 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
NO! You need an underground splice kit, sold at the box stores.
If this is coming from your panel, then the POCO would not locate it for you.
jbfan is online now   Reply With Quote
Old 09-21-2010, 03:50 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and if you haven't already done so, turn off the power until it is repaired. A cut line may not trip a breaker.
one neat thing if it doesn't trip the breaker but it does contact the Earth; it makes a nice resistance heater and that spot will stay thawed all winter long.
a real expensive to run heater.
Old 09-21-2010, 04:47 PM   #4
The breaker is off.LOL. The wires were stretched so I will have to cut them on both ends. Then put in about a 10 inch piece. So will a shrink kit still work? Don't know much about them, but will look them up if it will.
Old 09-21-2010, 04:50 PM   #5
nap
You talking to me?
nap's Avatar
yes. an underground splice is legal and dependable, when installed properly.
Old 09-21-2010, 09:27 PM   #6
Thanks for the help, I'll look them up and get it fixed.
Waverly
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 07:11 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
DIY 200A main service upgrade? Philip_Soldat Electrical 54 09-07-2008 11:02 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
