Underground Run To Outlet For Pool. LB Fitting Out Of Siding? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 06:37 PM   #31
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by collegetry View Post
thanks for all the info but what in the world does a single locking grounding type GFI look like?
It doesn't exist as stated, you use a twist lock receptacle and provide gfci protection via gfci breaker or faceless gfci.
Old 06-26-2012, 06:24 AM   #32
Rewards Points: 242
I know what a GFCI breaker is but if the pool pump has a "normal" 3 prong plug(hot-neutral-groun), is a twist lock outlet made for that?
collegetry is offline   Reply With Quote
Old 06-26-2012, 04:08 PM   #33
E2 Electrician
You would replace the 'normal' 3 prong plug with a twist lock style cord cap.
You are only allowed a 3' cord by the way, so make sure your pool filter pump is not installed right next to the pool like most installations I see.
Old 06-26-2012, 04:50 PM   #34
Rewards Points: 242
That would involve removing the "normal" 3 prong plug and cord and replacing with what you have pictured. You would think the pump moter would come with that plug/cord already attached.
Old 06-26-2012, 05:37 PM   #35
E2 Electrician
What type of pool do you have? Also, how long is the cord already installed?
What you might have is a temperory cord pre installed, I have seen those before and they come with a warning label.
Old 06-26-2012, 10:16 PM   #36
011010100110111101100101
Rewards Points: 160
Originally Posted by darren View Post
Yesa PVC LB will do the trick and not look bad. If you are using PVC for the whole run you will need an expansion joint under the LB so when he frost gets in the ground and moves the ground, the pipe will have some where to move instead of pulling out of the LB.
I got gonged for the first time this past summer for no expansion joint on sched 40 PVC coming out of an LB going to earth. 352.44 I believe it is. Same inspector never mentioned it before on any of my previous jobs of the same type...
-- Joe
anesthes is offline   Reply With Quote
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 09:48 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
