Underground Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 04:07 PM   #1
Rewards Points: 248
underground junction box?
Is it possible/wise to have an underground junction box? I have two storage sheds. Want to run one conduit the major distance then branch out locally. Do I need to make the connection above ground or is it possible to do something below? I'm using PVC conduit.
jackwashere is offline   Reply With Quote
Old 06-09-2012, 04:23 PM   #2
Rewards Points: 826
All junctions have to be accessible by code. That rules out a buried junction. Either run it all the way to one shed then to the other or go to common point and put in a weatherproof junction box above ground to do the connections. Maybe a way to get a yard GFCI outlet?
curiousB is offline   Reply With Quote
Old 06-09-2012, 04:33 PM   #3
Rewards Points: 266
If you really want to split underground, you could use a quazite box:
junkcollector is offline   Reply With Quote
Old 06-09-2012, 05:09 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not entirely true. There is an exception to 314.29.
Old 06-09-2012, 05:36 PM   #5
Rewards Points: 826
Ok I was thinking the op wanted to bury a conduit fitting like an LL body or just splice wires in the trench.
A special in ground junction box would be ok I guess
Old 05-29-2015, 02:14 AM   #6
Rewards Points: 2
junction box
quote junction box
jerryboisvert is offline   Reply With Quote
Old 05-29-2015, 08:44 AM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
The exceptions are very limited. They make it essentially little different than have an in ground box. If a person must install markers for the box (part of the exception, they might as well install a box above ground and put in a yard receptacle like another suggested.
The Following User Says Thank You to nap For This Useful Post:
BlakeL (06-09-2016)
Old 05-29-2015, 08:47 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
zombie thread!
The Following 2 Users Say Thank You to jbfan For This Useful Post:
clw1963 (05-29-2015), stickboy1375 (05-30-2015)
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
underground electical lines BlueBSH Electrical 11 02-10-2012 03:52 AM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 11:46 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
