Old 01-29-2008, 06:31 PM   #1
Underground Electrical Line and water line.
Premise: Underground electrical cable buried at a depth of 2 ft.
Is it permissible by code to have a water line cross this feed above it by about a foot (or at all)?
Randell Tarin is offline   Reply With Quote
Old 01-29-2008, 06:55 PM   #2
There is no requirement for spacing between electric and water lines.
That being said, it is normal for the water line to be deeper, so it will not be as likely to freeze in the winter.
Master Electrician
jwhite is offline   Reply With Quote
Old 01-29-2008, 07:04 PM   #3
Yeah, but I live in Texas and the frost line is at about 1 foot. Where the two will cross is near the structure I'm building, so I was going to put the electrical in conduit to protect it from digging later on.
So does the electrical go on top of the water line?
Old 01-29-2008, 07:07 PM   #4
If you are talking about the utility's service conductors it's a different story and each has it's own rules. Here it is 1' seperation between water and CONDUIT, 2' if parallel.
220/221 is offline   Reply With Quote
Old 01-29-2008, 07:08 PM   #5
depends on how deep the water line is
Old 01-29-2008, 07:18 PM   #6
No this is a subpanel feed from the MAIN. The water line will be about 1 foot deep.
Old 01-29-2008, 11:09 PM   #7
Union Electrician
goose134's Avatar
Depends on the raceway and size of the sub panel. If it is more than 20 A and in PVC, then it has to be buried 18 in. (12 with 2" of concrete fill) If you go with rigid conduit (GRC not EMT) the depth will be reduced to 6" no concrete fill. I haven't met a shovel yet that could beat rigid conduit.
Well not a hand shovel anyway...
goose134 is offline   Reply With Quote
Old 01-29-2008, 11:14 PM   #8
I like the idea of the concrete. I've already got a 2 ft. deep trench for the electrical line. I'll add concrete for good measure, though I doubt that the area will ever be dug in the future.
Thanks for all the input guys.
Old 01-29-2008, 11:33 PM   #9
Then it will be under.
PVC is superior to RMC in my geographical location. Steel deteriorates (rusts) and PVC does not.
Concrete is over kill and you can't put a shovel thru schedule 40 PVC.
Old 09-18-2011, 05:07 AM   #10
OOPS! Double tapped. See below.
Mustang Gregg is offline   Reply With Quote
Old 09-18-2011, 05:10 AM   #11
OOPS! I have put a spade into schedule 40 PVC before.
But not on purpose!
Putting concrete in a trench above your lines would sure make it hard to make repairs later.
MHOO,
Mustang Gregg
Old 09-18-2011, 09:19 AM   #12
I=E/R
a7ecorsair's Avatar
But not on purpose!
MHOO,
Mustang Gregg
Hi, You are new to the forum. Watch the dates on postings you reply to. This one is three years old..
a7ecorsair is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 07:06 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
