-   -   Underground Electrical Line and water line. (http://www.diychatroom.com/f18/underground-electrical-line-water-line-16337/)
Randell Tarin 01-29-2008 05:31 PM
Premise: Underground electrical cable buried at a depth of 2 ft.
Is it permissible by code to have a water line cross this feed above it by about a foot (or at all)? :huh:
jwhite 01-29-2008 05:55 PM
There is no requirement for spacing between electric and water lines.
That being said, it is normal for the water line to be deeper, so it will not be as likely to freeze in the winter.
Randell Tarin 01-29-2008 06:04 PM
Yeah, but I live in Texas and the frost line is at about 1 foot. Where the two will cross is near the structure I'm building, so I was going to put the electrical in conduit to protect it from digging later on.
So does the electrical go on top of the water line?
220/221 01-29-2008 06:07 PM
If you are talking about the utility's service conductors it's a different story and each has it's own rules. Here it is 1' seperation between water and CONDUIT, 2' if parallel.
220/221 01-29-2008 06:08 PM
depends on how deep the water line is :)
Randell Tarin 01-29-2008 06:18 PM
No this is a subpanel feed from the MAIN. The water line will be about 1 foot deep.
goose134 01-29-2008 10:09 PM
Depends on the raceway and size of the sub panel. If it is more than 20 A and in PVC, then it has to be buried 18 in. (12 with 2" of concrete fill) If you go with rigid conduit (GRC not EMT) the depth will be reduced to 6" no concrete fill. I haven't met a shovel yet that could beat rigid conduit.
Well not a hand shovel anyway...
Randell Tarin 01-29-2008 10:14 PM
I like the idea of the concrete. I've already got a 2 ft. deep trench for the electrical line. I'll add concrete for good measure, though I doubt that the area will ever be dug in the future.
Thanks for all the input guys.
220/221 01-29-2008 10:33 PM
Then it will be under.
PVC is superior to RMC in my geographical location. Steel deteriorates (rusts) and PVC does not.
Concrete is over kill and you can't put a shovel thru schedule 40 PVC.
Mustang Gregg 09-18-2011 04:07 AM
OOPS! Double tapped. See below.
Mustang Gregg 09-18-2011 04:10 AM
OOPS! I went and done it.
OOPS! I have put a spade into schedule 40 PVC before.
But not on purpose!:mad:
Putting concrete in a trench above your lines would sure make it hard to make repairs later.
MHOO,
Mustang Gregg
a7ecorsair 09-18-2011 08:19 AM
MHOO,
Mustang Gregg
Hi, You are new to the forum. Watch the dates on postings you reply to. This one is three years old..
