Underground Electrical Conduit Through Wall, Height? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 03:15 PM   #1
Question
underground electrical conduit through wall, height?
Running electrical conduit from 24" underground up through a wall to the inside of my garage for a sub-panel.
What height off the ground should my exit from the house and entry be into the garage?
spdorsey is offline   Reply With Quote
Old 01-12-2012, 03:30 PM   #2
Julius793's Avatar
What ever is convenient
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-12-2012, 03:31 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id normally take it out of house at sill plate level,once it gets to the garage id normally bring it out of the ground about 12" in pvc then convert it to emt up to the bottem of your disconnect box on outside of garage if youre installing one.
If youre not installing disconnect id bring the emt up to bottem of an LB then go right into the back of panel at closest knock out
plummen is offline   Reply With Quote
Old 01-12-2012, 03:55 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by plummen View Post
Id normally take it out of house at sill plate level,...
...or not even try to hit a sill.
Trench up to the wall and elbow up OUTSIDE of it.
Then an LB fitting into the panel.
hth
Old 01-12-2012, 09:56 PM   #5
plummen's Avatar
yeah I meant to say rim joist,just above sill plate!
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 08:17 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Electrical size conduit question pauls Electrical 12 12-03-2008 09:22 PM
Minimum wall thickness for electrical dc4nomore Electrical 10 10-10-2008 08:00 PM
