Underground Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 11:04 AM   #1
Underground electric
i want to run an underground electric line from my garage to a small pond pump. it will be 70', buried at about 18" depth, run through 3/4" pvc pipe. what type of wire do i need to use so it's safe? i'll probably use 14/2.
jjjeno is offline   Reply With Quote
Old 04-08-2011, 11:08 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
underground, something like THWN would be correct. Note the "W" in the designation. That means it is rated for wet conditions, which underground conduit is.
but #14? why? That would limit you to a 15 amp breaker and due to the distance, you should also consider voltage drop as well, especially with a motor.
what is the current draw of the pump?
Old 04-08-2011, 11:50 AM   #3
the pump is labled 115 v/60hz/45watts/.8 amps
I was only thinking 14/2 because that's what I think the line I was going to tap off of is. There might be a 12/2 line in the garage i can tap instead. i was trying to avoid running a line all the way to the circuit box.
Old 04-08-2011, 11:54 AM   #4
nap
You talking to me?
nap's Avatar
never mind. If you are talking less than an amp, you shouldn't have any trouble with the #14.
I deal with commercial electrical and when somebody speaks of a pump for a fountain or water pump, I typically think of a couple horsepower or so.
Is this a plug in unit or hardwired? You should have the circuit protected bt GFCI at some point.
Old 04-08-2011, 01:07 PM   #5
Rewards Points: 1,016
Being a single 120v circuit, this conduit can be buried just 12" - someone please confirm or correct?
Old 04-08-2011, 03:57 PM   #6
Scared Electrician
Saturday Cowboy's Avatar
see 300.5
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-08-2011, 04:21 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
To meet the requirement for burial depth, it has to be GFCI protected before it goes underground. There are other requirements that are not important for this application.
Coastal South Carolina
Old 04-08-2011, 10:06 PM   #8
Ah yes - thanks I had forgotten the important GFCI requirement. Thanks.
____________
Vince
Old 04-08-2011, 10:30 PM   #9
Journeyman Wireman
Rewards Points: 150
iYes, If the circuit is 120v, not exceeding 20a and is GFCI protected.
Jupe Blue is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
underground electric wiring Bob P Electrical 11 03-22-2011 03:04 PM
underground electric under pond jason7858 Electrical 35 01-10-2011 04:52 PM
underground water and electric handifoot Electrical 9 05-06-2009 10:13 AM
Design an outside underground electric system??? antiqking Electrical 6 09-13-2008 11:28 AM
