Underground Conduit With Underground LB - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 01:05 PM   #1
Underground conduit with underground LB
A couple of years ago, I ran a 20 foot underground run sch 40 with 12ga THWN. The run is under my lawn and goes from my house to a remote gfi outlet in my yard, the outlet box is bolted to a 4x4 riser. Here's my concern, I messed up and didn't allow enough wire to come up to the remote outlet, so I put in an LB directly under the outlet (about 18 inches underground) to connect another leg of THWN up to the outlet. I connected the wires with wire nuts and smeared a bead of silicon around the cover of the LB to help keep water out.
Is this okay and safe, or should I dig this up and run a new "unbroken" length of wire though the conduit and remove the LB?
kevinf. is offline   Reply With Quote
Old 10-08-2012, 01:44 PM   #2
Rewards Points: 2,512
If it is only a 20 foot run of 12 THWN inside of PVC conduit, it would not be too difficult to pull new wire.
I do not think that the PVC LB's, even with silicone, are made to be underground.
hammerlane is offline   Reply With Quote
Old 10-08-2012, 01:59 PM   #3
You're right, it wouldn't be hard to do, just the cost of the new wires and my time and effort. But to my main concern, is the way I have it set up now unsafe? Even though it's not right, am I correct that it is not a safety hazard because it's a gfi outlet?
Old 10-08-2012, 02:31 PM   #4
Oso954's Avatar
Rewards Points: 442
A GFCI outlet protects what is downstream. Any thing plugged into it, and if wired as a load, the wiring and additional outlets beyond it. Your underground wiring is not GFCI protected by that outlet.
What type of wire nuts did you use ? Same as indoors ? Not an approved method.
If code is the minimum safety standard, anything less than code is unsafe.
Oso954 is online now   Reply With Quote
Old 10-08-2012, 02:33 PM   #5
Rewards Points: 734
Odds are that you'll find that conduit full of water. Your connections are then in water.
Moisture does accumulate in conduit.
Was the LB marked as to it's volume? If not, you can't use it for your splices. In addition, you don't meet Code.
314.29 Boxes, Conduit Bodies, and Handhole Enclosures to Be Accessible. Boxes, conduit bodies, and handhole enclosures shall be installed so that the wiring contained in them can be rendered accessible without removing any part of the building or, in underground circuits, without excavating sidewalks, paving, earth, or other substance that is to be used to establish the finished grade.
Fix it.
AandPDan is offline   Reply With Quote
Old 10-08-2012, 02:42 PM   #6
Thanks. I used standard nuts used indoors. Pretty easy decision here, I'll just fix it, no big deal to do. Here's some more info, this is a switched circuit, so am I right that no harm can be done as long as it's switched off, until I can fix it right?
Old 10-08-2012, 02:46 PM   #7
Fix it.
Thanks! How can water get into the conduit if it's sealed (glued connections)? Does the moisture seep though the connections? If so, is there a way to prevent it?
Old 10-08-2012, 03:07 PM   #8
Rewards Points: 1,192
Underground conduit is a a wet location.
bobelectric is offline   Reply With Quote
Old 10-08-2012, 04:18 PM   #9
Electrician
Rewards Points: 150
Condensation eventually fills the conduit. Use electricians duct seal around the wires to seal both ends of the conduit.
Glennsparky is offline   Reply With Quote
The Following User Says Thank You to Glennsparky For This Useful Post:
kevinf. (10-08-2012)
Old 10-08-2012, 04:51 PM   #10
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You can replace the LB with an underground junction box. The top would be just at or below the surface so your joints are accessible.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
Old 10-08-2012, 05:04 PM   #11
Thanks. So for a different, but related question, would you recommend drilling small weep holes in above-ground junction and gang boxes? Or would this be unnecessary? I have several outdoor runs in my yard with outdoor covers and PVC junction boxes.
Old 10-08-2012, 05:27 PM   #12
Electrician
Rewards Points: 760
unfortunately us professionals on the site will not tell you what you want to hear. Your best bet is to dig up the LB, extend the pipe up to your plug and pull new wire.
darren is offline   Reply With Quote
Old 10-08-2012, 05:50 PM   #13
Resi EC
Rewards Points: 252
I have done this, but it is not necessary.
I have opened old weather resistant boxes, holding the water in just fine.
Gac66610 is offline   Reply With Quote
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
Sealing an underground conduit for future use Bob_T Electrical 7 05-31-2011 11:01 AM
How to seal underground conduit. jrepp44 Electrical 1 01-12-2011 12:09 PM
Underground Conduit donnyc Electrical 1 09-20-2010 02:29 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
