-   -   underground conduit to power up a garden shed (http://www.diychatroom.com/f18/underground-conduit-power-up-garden-shed-78460/)
HappyHome 08-11-2010 07:35 AM
Hi,
What type of conduit do I need to run electrical to my garden shed? The conduit will be buried from the house to inside the shed (up through the floor). Do I need solid plastic type that requires glue at each connection or can I use that corrigated stuff with those quick connects?
Any help is grealy appreciated.
Regards
COLDIRON 08-11-2010 07:40 AM
I would run regular electrical conduit , the gray stuff .. make sure you have enough room to pull easy follow NEC as far as depth.
secutanudu 08-11-2010 07:59 AM
Where are you located?
Use PVC conduit, the kind you glue at each connection. It is gray, not white. In most areas. if the circuit is not GFCI protected, you must bury 18". If it is GFCI, you can go 12". Those measurements are to the top of the conduit. Local codes could change those depth requirements.
Can you provide some more details about what you're doing? Just running a single circuit? Subpanel? Breaker & wire size?
HappyHome 08-11-2010 08:20 AM
in response..
I live in Ontario Canada.
The conduit/electrical will provide power to garden lights, pool lights, shed light (inside) and pot lights in the soffit. As well, some outlets inside the shed for say a small bar fridge, blender, and music source. There are two 15 amp circuits available from a subpanel that is being used to supply power to the pool pump.
Thanks for all the quick responses.
Regards
HH
Proby 08-11-2010 08:53 AM
Are there two empty breakers in this pool subpanel? What I am asking is why you think there are only 15 amp circuits available in this panel?
Where is this pool sub panel? Where is your main panel located?
HappyHome 08-11-2010 04:46 PM
Hi,
there are two empty breaker slots in the subpanel. The subpanel is powered by a 30 amp breaker.
The current subpanel is at the side of my house. I would need to run conduit from the side to the back (about 10 feet) then to the shed/cabana, another say 30-40 feet.
The main panel is along the same wall of the subpanel, about 15 feet way from where the main panel is to where the current cable exits the house to feed the subpanel.
Hope this helps.
Regards
HH
