Old 09-20-2010, 12:22 AM   #1
Question
Underground Conduit
I am in the process of landscaping my backyard and preparing for future pool services (electrical & gas). I pulled a permit to run gas (2" PE) & electrical (2" PVC) to my backyard and stub it just past my proposed side-yard concrete. Gas was installed by licensed plumber already. Electrical still awaiting installation (considering doing myself because only conduit & no tie-ins at the moment). I am not sure what the general electrical codes are for installing electrical conduit in Contra Costa County, CA. Does gas & electrical need any separation when in same trench, or can they just sit on one another? Can I just place a conduit cap on each end that I stub out of the ground, or do I need a junction box? Can I back-fill the trench was the soil that was excavated, or do I need sand,...?
Thank you
donnyc is offline   Reply With Quote
Old 09-20-2010, 02:29 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Underground Conduit
Normally the electrical conduits are buried 18 inches down from the finshed grade some local codes may say diffrent.
You will need to bring full 4 conductor and unforetally no bare conductor is allowed and there are a bit of codes to cover with swimming pools and they are very strict with it.
Some local area they will not allowed homeowner to hook up the power for the pool it have to be done by licesed electrician to do this.
So the size of pool subpanel will depending on the way you want to set up the pool like pump size , lighting lay out etc
and if the trench is pretty wide you can lay electrical conduit and gaz pipe near each other but all it depending on your local codes.
Merci.
Marc
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
underground conduit to power up a garden shed HappyHome Electrical 5 08-11-2010 04:46 PM
How to plug unwanted and leaking conduit? gernith General Discussion 6 08-08-2010 01:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
