Underground Cabling Splice Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2006, 02:06 AM   #1
Underground cabling splice question
I am doing a project out in the yard with the UF 12/2 wire, what I need to do is splice three wires together, anyone know if the following will allow me to use three wires in it?
http://www.amazon.com/GB-Electrical-.../dp/B00004WLKR
http://www.foxelectricsupply.com/con...roductNo=67000
rnichols is offline   Reply With Quote
Old 10-23-2006, 04:49 PM   #2
World famous jerk.
No, none of those UF splice kits will permit you to splice 3 UF cables together. They are both for ONE cable to ONE cable. To do what you want, use "underground wire nuts", sometimes called "King wire nuts". They're basically regular wire nuts with silicone or siliconized grease in them. Here's a tip that I use sometimes to splice multiple UF's... Before you splice them together, slide a piece of 1-1/2 or 2" PVC pipe over one of the cables. Make your splice using underground wire nuts. Slide the PVC pipe over the splice, centering up the splice. Spray some spray foam in each end of the pipe to encapsulate the splice. Allow the foam to cure then bury the splice.
mdshunk is offline   Reply With Quote
Old 10-24-2006, 07:39 AM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Are you asking about splicing three wires or three cables?
J187 is offline   Reply With Quote
Old 10-24-2006, 09:40 AM   #4
Yes, three cables..
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
Ready to lay laminate... Question... KUIPORNG Flooring 6 04-13-2007 02:17 PM
