Underground Cable - Any Way To Tell? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 03:32 PM   #1
Rewards Points: 248
Underground cable - any way to tell?
I see alot of cable offered on craigslist material. Only problem is I don't know which is suitable for underground pvc conduit burial. Is there any easy way to tell?
jackwashere is offline   Reply With Quote
Old 03-01-2012, 03:37 PM   #2
Rewards Points: 13,694
If it's all in conduit any wire will work. If it's direct burial it needs to be UF.
Old 03-01-2012, 04:33 PM   #3
Master Electrician
Rewards Points: 3,864
Totally inaccurate.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
plummen (03-01-2012)
Old 03-01-2012, 04:37 PM   #4
Well then clear it up for him.
Old 03-01-2012, 04:44 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The cable has to be rated for direct burial. I would suggest asking the seller what the rating is and ask someone here or look it up to find out if it's rated for direct burial.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-01-2012, 05:18 PM   #6
I=E/R
a7ecorsair's Avatar
Do not buy any used cable if you cannot read the rating printed on the sheathing.
a7ecorsair is offline   Reply With Quote
Old 03-01-2012, 07:43 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Originally Posted by brric View Post
Totally inaccurate.
Wire in underground conduit needs to be rated for a wet location. THWN meets the requirement and is the most obvious choice.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-01-2012, 08:47 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,938
Only if it's going to be direct buried. If it's in conduit, it just needs to be wet rated.
mpoulton is offline   Reply With Quote
Old 03-01-2012, 09:33 PM   #9
rrolleston's Avatar
Old 03-02-2012, 06:24 AM   #10
Rewards Points: 3,130
This. Most will be rated THHN/THWN. Any big box store will have what you need, sold by the foot. It's probably a lot cheaper than UF cable.
Old 03-02-2012, 12:45 PM   #11
Rewards Points: 81
Or find an electrical supply house. The one I use sells wire by the foot at FAR less than what I've paid at the Orange Apron store... Like half.
JeepNick is offline   Reply With Quote
Old 03-02-2012, 12:48 PM   #12
Rewards Points: 248
So if it is THHN or THWN I am good and can use it for burial in underground pvc conduit. Correct?
Old 03-02-2012, 12:55 PM   #13
rrolleston's Avatar
THWN is wet rated.
What will you be running with this cable?
Old 03-02-2012, 01:09 PM   #14
A "Handy Husband"
rjniles's Avatar
It is THWN, but most wire today is dual rated THHN/THWN. THHN is for dry location conduit.
Running underground cable across my yard blue sky Electrical 11 12-31-2011 01:35 PM
Cat 5 Cable Underground regularguy Electrical 4 10-28-2011 04:41 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Underground Cable Question Livewire78 Electrical 7 12-09-2009 12:15 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
