Old 10-06-2012, 12:56 PM   #1
Undergrond electrical circuit GFI placement
I am running an underground circuit from the panel in the house to my shed using UF 10/2 wgnd .
Adding a new 20 amp breaker and a switch at the house end.
where do I need the GFI does it need to be before the under ground section?
Can I just put a GFI recptacle at the shed?
It's 120' underground and proably another 30 through the attaced garage and into the house. That's why the awg 10.
rshort is offline   Reply With Quote
Old 10-06-2012, 04:33 PM   #2
Master Electrician
Doesn't matter as long as there's a gfci somewhere. Personally I would run 12/3 with ground. Multi wire branch circuits have Minimal cost difference and max available current without a subpanel.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-06-2012, 04:46 PM   #3
A "Handy Husband"
rjniles's Avatar
If you are in the USA:
If the GFCI is in the house before the cable goes underground, you only need to trench 12" deep.
If the GFCI is in the shed, the trench needs to be 24" deep.
How long is the run that you think you need #10 for a 20 amp circuit?
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
electures (10-06-2012)
Old 10-06-2012, 04:48 PM   #4
Electrical Contractor
You asked the same question yesterday and got the same answers.
Are you looking for another answer?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following 2 Users Say Thank You to jbfan For This Useful Post:
electures (10-06-2012), rjniles (10-06-2012)
Vexing Electrical Circuit Problem skulzer Electrical 6 01-29-2012 07:41 PM
Bull Dog Pushmatic Electrical panel and Circuit Breakers highdeserthome Electrical 34 01-27-2012 02:06 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Electrical Circuit Doesn't Work kcrossley2 Electrical 11 05-21-2009 05:22 PM
