Undercabinet Surface Mounted Box For Disposal Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 12:09 AM   #1
Undercabinet Surface Mounted Box for Disposal Plug
Replacing my disposal from a batch to a continuous. The new one has a plug the old one did not. So I plan to use the Romex line to a surface mounted outlet box in the cabinet. What kind of box is permitted? I have a white metal Wet Location Box, and a plastic Carlon box that the store rep said was fine. But it says wall or ceiling mount only, and because the cabinet back sits off the wall by an inch I thought screwing into the side of the cabinet was most stable.
Also, can I use one of the proper rated remote appliance switches plugged in the outlet (per above) to control the disposal, rather than putting a wall swtich?
xd11 is offline   Reply With Quote
Old 12-03-2010, 12:16 AM   #2
Electrical Supplier
Rewards Points: 150
I dont know about switches, but as far as the box will go, I would use a metal Handy Box with knock outs. Thats all you really need. Make sure you ground the box.
You dont need a wet location box there. Without a weatherproof in use cover, its kind of pointless.
LyonsElecSupply is offline   Reply With Quote
Old 12-03-2010, 10:38 AM   #3
Lyons,
Thanks. I had the Outdoor box in my basement for two years and the Carlon was only 69 cents so no big deal either way; I can use a metal handy box. Is the romex from the old disposer-direct connection ok or do I need to replace it with BX to go to the new outlet box?
Old 12-03-2010, 10:48 AM   #4
the Musigician
DangerMouse's Avatar
This may depend upon your location.
Where are you?
DM
Old 12-03-2010, 03:55 PM   #5
NJ. Single Family Home.
Old 12-04-2010, 09:40 AM   #6
Electrical Supplier
Rewards Points: 150
NEC says no, but local code may require MC.
If you enter from the wall directly into the box, just use a romex connector and you should be fine.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
Out door plug Red Squirrel Electrical 11 09-06-2009 08:04 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
